Author Topic: not work  (Read 18187 times)
Offline AigarsTopic starter
  • Country: is
  • elerepair
Re: not work
« Reply #25 on: May 28, 2014, 03:21:36 pm »
no, its connected corect. its samthing ealse. hu can give me new plate scheme and soft. i can build new
I guess you're not interested in learning anything, then.
comoon, why not. i mace corect, but samthing not corect.
i tray many difirent thinks. mor easy for me make a new board and program new soft.
Online Neganur
Re: not work
« Reply #26 on: May 28, 2014, 03:43:27 pm »
OK, it seems at least the contrast is working then (compared to the first pictures you posted) and I assume you have tried to adjust the pot to get the best contrast setting.
If the display is not showing anything, it could be your microcontroller that is not running the code as it should.
I have to ask though to be able to guide you a little better, what is is your experience in electronics? Hobbyist? Got a multimeter around? I assume you etched the board yourself?
Can you post a couple of photos of the bottom (solder side) of the board with as little reflections from the flux as possible (different angles)? It might be something as simple as a short circuit somewhere. It looks like your transistors and everything else are soldered in correctly, although I'm not sure if I like the floating /RESET pin.
  • Country: is
  • elerepair
Re: not work
« Reply #27 on: May 28, 2014, 04:11:41 pm »
 ok i clean flux and make sam piktures mor.
Offline lapm
Re: not work
« Reply #28 on: May 28, 2014, 04:12:07 pm »
This thread reminds me of old advice i got once: Forget the things that works from power up, you learn much more from those that didint...
Electronics, Linux, Programming, Science... im interested all of it...
  • Country: is
  • elerepair
Re: not work
« Reply #29 on: May 28, 2014, 04:24:19 pm »
there its sam mor pic
  • Country: is
  • elerepair
Re: not work
« Reply #30 on: May 28, 2014, 04:26:13 pm »
ya i building may self. i working wif pc. i fixing mb and many moor stufs.
Offline Monkeh
Re: not work
« Reply #31 on: May 28, 2014, 04:39:21 pm »
Why is the reset pin floating?
Offline Hydrawerk
Re: not work
« Reply #32 on: May 28, 2014, 04:56:08 pm »
What is wrong with that?
EDIT: Sorry, i made a mistake.
« Last Edit: May 28, 2014, 05:03:53 pm by Hydrawerk »
Offline Monkeh
Re: not work
« Reply #33 on: May 28, 2014, 04:57:25 pm »
Well if it's being used as a reset pin, you'll get spurious resets. Or just end up with it being held in reset.
Offline PA0PBZ
Re: not work
« Reply #34 on: May 28, 2014, 05:00:47 pm »
Also there is no external clock. I can't look into the software from here but most of these atmega component testers use an external clock.
Offline Hydrawerk
Re: not work
« Reply #35 on: May 28, 2014, 05:05:11 pm »
It depends on the MCU settings. It can run with or without an external crystal. You must set the MCU's fuses correctly.
Offline PA0PBZ
Re: not work
« Reply #36 on: May 28, 2014, 05:09:11 pm »
That is what I mean, you have to load the correct firmware. The design linked to earlier has 3 different designs with of course different firmware files! I just hope he picked the correct one...
  • Country: is
  • elerepair
Re: not work
« Reply #37 on: May 28, 2014, 05:25:06 pm »
MABY, I DONT KNOW. CAN U HELP GET CORECT? OR MABY FILES FOR NEW PLATE AND SOFT?
Offline PA0PBZ
Re: not work
« Reply #38 on: May 28, 2014, 05:28:54 pm »
Start by doing what you should have done in your first post:
 - Post a link to the design you built
 - Post a link to the firmware you used
We can go from there.
  • Country: is
  • elerepair
Re: not work
« Reply #39 on: May 28, 2014, 06:06:43 pm »
i dont know mor. i ben downloaded and ........ .
Offline PA0PBZ
Re: not work
« Reply #40 on: May 28, 2014, 06:15:41 pm »
I don't think I can help you without that basic information.
  • Country: is
  • elerepair
Re: not work
« Reply #41 on: May 28, 2014, 06:18:35 pm »
ok. maby u can give me board schematic and soft?
that what u know its work
Offline Monkeh
Re: not work
« Reply #42 on: May 28, 2014, 06:22:05 pm »
If you managed to download it, surely you can tell us where?
Offline PA0PBZ
Re: not work
« Reply #43 on: May 28, 2014, 06:23:52 pm »
Sorry, I never built one.
  • Country: is
  • elerepair
Re: not work
« Reply #44 on: May 29, 2014, 12:01:23 pm »
hi. can samone give me transistor tester eagle files and hardware?
Offline Monkeh
Re: not work
« Reply #45 on: May 29, 2014, 12:07:53 pm »
 |O
  • Country: is
  • elerepair
Re: not work
« Reply #46 on: May 29, 2014, 01:00:58 pm »
Offline madires
  • A qualified hobbyist ;)
Re: not work
« Reply #47 on: May 29, 2014, 02:00:02 pm »
The official project site is http://www.mikrocontroller.net/articles/AVR_Transistortester and you'll find the links to the downloads at the bottom.
Offline PA0PBZ
Re: not work
« Reply #48 on: May 29, 2014, 02:12:26 pm »
i think, from there coming may tester
http://mdiy.pl/uniwersalny-tester-elementow-na-avr/
That looks like it yes.
Now where did you get the software?
(you did program the chip did you?)
  • Country: is
  • elerepair
Re: not work
« Reply #49 on: May 29, 2014, 04:05:59 pm »
i can not finde :(
