Author Topic: Not very ABLE to do ABEL... GAL 16V8  (Read 640 times)
Offline NivagSwerdnaTopic starter
« on: June 16, 2020, 06:05:42 pm »
I am struggling with my very first GAL design...
MODULE test2
 A15 pin 1;
 A14 pin 2;
 A13 pin 4;
 A12 pin 5;
 A11 pin 6;
 ROM_ENABLE_B   pin 9;
 ROM_ENABLE_C   pin 11;
 ROM_ENABLE_D   pin 17;
 ROM_ENABLE_E   pin 14;
 ROM_ENABLE_F   pin 13;
 ROM_CHIP_DISABLE    pin 19;
H,L,X = 1,0,.X.;
 Address = [A15,A14,A13,A12, A11,X,X,X, X,X,X,X, X,X,X,X];
 ROM_RANGE_B, ROM_RANGE_C, ROM_RANGE_D, ROM_RANGE_LOW_E, ROM_RANGE_F node;
 ROM_RANGE node;
 ROM_CHIP_ENABLE node;
equations
 ROM_RANGE_B      = ((Address >= ^hB000) & (Address <= ^hbfff)) & ROM_ENABLE_B;
 ROM_RANGE_C      = ((Address >= ^hC000) & (Address <= ^hCFFF)) & ROM_ENABLE_C;
 ROM_RANGE_D      = ((Address >= ^hD000) & (Address <= ^hDFFF)) & ROM_ENABLE_D;
 ROM_RANGE_LOW_E  = ((Address >= ^hE000) & (Address <= ^hE7FF)) & ROM_ENABLE_E;
 ROM_RANGE_F      = ((Address >= ^hF000) & (Address <= ^hFFFF)) & ROM_ENABLE_F;
 ROM_RANGE = ROM_RANGE_B # ROM_RANGE_C # ROM_RANGE_D # ROM_RANGE_LOW_E # ROM_RANGE_F;
 ROM_CHIP_ENABLE = ROM_RANGE;
 ROM_CHIP_DISABLE = !ROM_CHIP_ENABLE;
END
The trouble is that I end up with a design that has the ! of what I wanted...
                                   P16V8AS
                     A15 |  1                    20  | Vcc
                     A14 |  2                    19  | !ROM_CHIP_DISABLE
                         |  3                    18  |
                     A13 |  4                    17  | ROM_ENABLE_D
                     A12 |  5                    16  |
                     A11 |  6                    15  |
                         |  7                    14  | ROM_ENABLE_E
                         |  8                    13  | ROM_ENABLE_F
            ROM_ENABLE_B |  9                    12  |
                     GND | 10                    11  | ROM_ENABLE_C
i.e. I get !ROM_CHIP_DISABLE on pin 19 but I wanted ROM_CHIP_DISABLE
Any clues?  something to do with istype?  something to do with my assumptions about how a GAL would work!??
Re: Not very ABLE to do ABEL... GAL 16V8
« Reply #1 on: June 16, 2020, 07:47:33 pm »
I tried something simpler...
MODULE test2
 IN1 pin;
 IN2 pin;
 IN3 pin;
 IN4 pin;
 OUT1 pin;
 OUT2 pin;
 OUT3 pin;
 OUT4 pin;
equations
 OUT1 = IN1;
 OUT2 = IN2;
 OUT3 = IN3;
 OUT4 = IN4;
END
and the compiler showed me....
                                   P16V8AS
                     IN1 |  1                    20  | Vcc
                     IN2 |  2                    19  | !OUT2
                     IN3 |  3                    18  | !OUT1
                     IN4 |  4                    17  |
                         |  5                    16  | !OUT4
                         |  6                    15  | !OUT3
                         |  7                    14  |
                         |  8                    13  |
                         |  9                    12  |
                     GND | 10                    11  |
                        SIGNATURE: N/A
which looked wrong... but i burnt it into a chip and tried it...
so weirdly the outputs don't actually seem to be inverted.  Now I am really confused!!!
« Reply #2 on: June 16, 2020, 11:24:10 pm »
I think maybe it is actually working... just the "Chip Report" .... "P16V8AS Chip Diagram"... is misleading.  Maybe ! means something different there???
