The voltage amp* inside a loop to regulate current?
*I don't suppose they make a current mode (Gm?) amp. Which is basically any normal amp, but without the compensation and low impedance follower inside. A voltage amp is normally made by intentionally slowing down a fast amp. The excuse is, the dominant pole compensation is easy to use?
It follows, to have good current accuracy you need stupid high gain outside the volt amp (if you're talking LM399, it better be a damned fine amp and current sensor!). Which means that amp has to be at least as slow as the volt amp, plus some headroom (expect maybe 1/3rd bandwidth overall).
The volt amp is dominant pole, but the pole moves up by the gain reduction. So at a gain of 10, it's GBW/10, etc... This makes it relatively easy to calculate the outer compensation too (if you were so inclined).
