@nukie
That explains it... It might be a common problem with these.
Were did you buy yours? I bought mine from Germany, ebay.
@Tom66
Thank you for the info. As you describe it it does look like type b, but I find it difficult to
see how it got contaminated. It is been used in a clean and dry environment.
I've seen the layering in other LCDs and there is a lot of space for disaster if you try to
disassemble them. Do you think that it might be just a case of contamination in between
the layers? (I am very curious now to open it and see what' s going on
When I heated the affected region with the heat gun on around 100 degrees Celsius,
the shadows disappeared. Can this happen if the mura is of type A?
(Mura in Greek are called all types of berries like blueberries etc...
Thanks.
