Hey Guys,
I'm working on a small project and require some guidance managing the hardware aspect (screws, mounting, holes).
This is supposed to be a simple wall clock. The clock has front and back rectangular panels made of acrylic. The electronics are to be housed between the two panels.
The front panel has numbers cut out and LEDs are supposed shine through the cutouts.
Below is an attempt at a technical drawing of what I had in mind. A and B are the acrylic front and back panels respectively, and C is the PCB. Panel D holds the LEDs which are mounted. E is the clock battery holder.
My design questions come in when I consider bringing all of these panels together; how can I join them, but also space them to my liking? Also, how could I electrically connect the LEDs to the PCB (simple wires to holes in the board, perhaps?)
