Author Topic: Network cable category wtf  (Read 2731 times)
Offline andtfootTopic starter
« on: June 26, 2014, 12:04:56 pm »
I'm just doing a training thingie (Telecommunications) for work, and littered throughout it are... odd ways of describing things.
Is it just me or does questions 4 and 5 in the quiz not make sense? (It's also how it's described in the text)
Now a half-educated guess would have me say that gigabit Ethernet is transmitted at the same frequency, regardless of the cable used (let alone that it's not the cable itself that is transmitting  :-DD ).
Offline madires
  • A qualified hobbyist ;)
Re: Network cable category wtf
« Reply #1 on: June 26, 2014, 12:19:04 pm »
The correct answer for that bad Q4 is Cat 5e. Cat 5 is specified for 100MHz but not for GigE usage. The minimum required category for GigE is 5e. The trainer failed the test  :-DD
BTW: The clock rate for GigE is 125MHz for each TP. It's the same for FastEthernet. Second fail  :-DD
« Last Edit: June 26, 2014, 12:26:15 pm by madires »
Offline Precipice
« Reply #2 on: June 26, 2014, 12:26:17 pm »
Wikipedia thinks not -
http://en.wikipedia.org/wiki/Gigabit_Ethernet
down at the bottom, the difference between 1000BASE-T and 1000BASE-TX
Offline HackedFridgeMagnet
« Reply #3 on: June 26, 2014, 12:39:46 pm »
Maybe
"What category of cable is characterised to 250Mhz." Might be a better question.
Most cables aren't intentionally transmitters.
Offline Fsck
  • sleep deprived
« Reply #4 on: June 26, 2014, 12:43:34 pm »
Maybe
yeah, the wording makes the incorrect fundamental concepts worse.
"This is a one line proof...if we start sufficiently far to the left."
Offline madires
« Reply #5 on: June 26, 2014, 12:50:29 pm »
You can run GigE on Cat 5, but it's not remommended. The specs of Cat 5 are at the fringe of what GigE requires. Long cables or poor installation (too small bend radius and so on) will give you broken frames and a lot of FCS errors. Anyone involved in structured wiring of datacenters will tell you to use Cat 5e at least for GigE. Cat 5e has better specs and allows some abuse of the cable without causing too much trouble.
Offline Richard Crowley
  • KJ7YLK
« Reply #6 on: June 26, 2014, 01:08:22 pm »
Just another example of being "copy edited" by non-technical people who likely "corrected" what they thought was "improper grammar".  Alas, you find this kind of problem in many places.  I call this "technical entropy."   :palm:
Offline Fsck
  • sleep deprived
« Reply #7 on: June 26, 2014, 01:12:29 pm »
same way that cat5e can work in clean environments in short runs for 10G.
