It is very hard to know until you have found the characteristics of the motor.
If you have a digital oscilloscope, what you probably want to do, if possible is have the motor and the 150V and a big 150V DC switch (has to be a genuine DC switch, no an AC rated switch). Across the motor, put a hefty 400V reverse biased diode - say 30A - in series with a power resistor. Something like 1 ohm, 20 watts.
Run the motor and capture the waveform across the motor when you switch it off. Try it unloaded and loaded.
From the captured waveforms, you can get an idea as to how much energy will need to be absorbed from the motor inductance. And from that you can calculate whether you can keep the voltage below 200V or not.
It may be that the motor's manufacturer already has good specs on the motor.
Richard.
