Author Topic: ways to turn a knob with a stepper motor and arduino  (Read 2767 times)
Offline StealthrtTopic starter
« on: March 24, 2017, 04:25:11 pm »
Hey all I am wondering what would be the best items to purchase for me to be able to turn this know (continuous) below:
I'm just needing to know what kind of servo torque I would need in order to turn that without issues of it getting stuck mid-ways.
i spoke to the original creator of that web site project that i linked to and this is what they had to say about the parts that were used:
We used a  small geared Maxon motor (great but expensive hi-tech stuff).
motor
RE-max 13 Ø13 mm, Precious Metal Brushes CLL, 1.2 Watt, with cables
Part-No.: 203888
gear
Planetary Gearhead GP 13 A Ø13 mm, 0.02 - 0.35 Nm, Metal version
Part-No.: 110316
Torque was on the low side: it was enough for regular cornflakes but clearly insufficient for muesli  :-)
The problem is not only about finding a motor with enough torque, it's  also about finding a motor small enough to fit in the dispenser.
Here are the files. The pulleys were 3D printed,
but the bracket was laser cut in 3mm acrylic glass.
Are there any servos that have a hole in the middle so that i can slide it over the turning rod and screw down to tighten on it in order to spin it as if you were spinning it yourself with the handle?
Something like this:
As I mentioned above, I would need the stepper motor to have a continuous rotation in order for it to work with either of these dry food dispensers above.
There is a decent tutorial HERE but really doesn't give much information about how they went about building it and the mentioned Yocto-LatchedRelay seems over priced for something that can be done with just a stepper motor and some logic behind it.
I plan on using a ATMEGA32u4 with this project. I will have a total of 6 of these to control.
The handle/shaft is 2 1/2" long.
The paddle is 3" long
The base (measured from the inside) is 5 7/4"
So any suggestions on what would be best for this type of project would be great and I look forward in hearing them! :)
Offline anishkgt
  • Country: qa
    • George Hobby
Re: ways to turn a knob with a stepper motor and arduino
« Reply #1 on: March 24, 2017, 04:41:38 pm »
Well the requirement for this project would come down to motor, servo and torque if am correct. The number of turns can be controlled with a steeper motor as well as servo. The continuous turn servo. There are servo's with enough torque to do the job or a 775 motor also would enough torque but in controllable spin though. Not sure if stepper motors would have enough torque. Servo would be best I guess with a shift couple and a 5 or 8mm rod to spin the knob. Servo on the when attached from arduino cannot spin freely unless it detached via code.
Hope this helps.
Sent from my iPhone using Tapatalk
Offline CM800
« Reply #2 on: March 24, 2017, 04:57:34 pm »
The torque would depend on what you have in it.
Looking at the design it could be the case where something get's stuck between the flap and the side, so you will need enough torque to be able to crush whatever you dispense (unless it's circular enough to allow to slip out of the way)
Offline james_s
« Reply #3 on: March 25, 2017, 12:36:35 am »
You can get inexpensive gearhead DC motors that have loads of torque. Expensive ones are available too but they're not all expensive.
Another cheap source is power window and wiper motors from cars, they tend to be a bit on the large side for a project like this but they can be found cheaply.
