You can point the receiver behind the TV to the wall to the right or left from the TV or to the ceiling but may be hard to find a right angle and the remote also will have to be pointed to the same surface at an angle which may be awkward and work only from a certain position of the person in the room, anywa you can try, in a small room may be enough reflection from the walls to trigger the receiver.
