Author Topic: (Datasheet added)Need help, Replace EVF micro-OLED with a big one  (Read 2023 times)
Offline LoganTopic starter
Hi.
I have a EVF with OLED model ECX334A.
I want to replace the micro-OLED with a normal LCD/OLED panel.
Please look at the 4 pictures:
1. Board with connector to host and convertor chip 358762G.
2. Detail for the 30-pin host connector.
3. Back of the micro OLED.
4. Socket and connector for the micro OLED.
I think if there's anything off-shelf compatible with either connector, it would be sweet.
Or in worst case, how can I enlarge the micro OLED optically so I don't need to push my eyeball into the tiny window?
Thanks.
Datasheet added in the later post.
« Last Edit: November 18, 2021, 03:00:55 pm by Logan »
Offline dmendesf
  • Country: br
Re: Need help, Replace EVF micro-OLED with a big one
« Reply #1 on: November 10, 2021, 12:06:48 am »
Didin't find a datasheet for it but found a product page for a similar unit that says it uses LVDS/sub-LVDS:
https://www.sony.com/en/SonyInfo/News/Press/201805/18-049E/
Probably you'll need to reverse engineer it with a scope, but as the resolution is fairly standard you can probably use a LVDS to HDMI converter:
https://geekworm.com/products/lvds-to-hdmi-adapter-board-converter-with-lvds-cable
The following users thanked this post: Logan
Online coromonadalix
« Reply #2 on: November 10, 2021, 12:30:06 am »
Even if you get a bigger screen    the coding is made for an X by X resolution, you wont get a better one if you resize the display, but you'll see the display better up to a point ...
« Reply #3 on: November 10, 2021, 11:02:52 am »
Thank you.
Mine use "RGB 24bit/YCbCr 16bit": https://www.sony-semicon.co.jp/e/products/microdisplay/oled/product.html
Combined with 358762G, I guess it's digital, so RGB signal is likely.
Do I have to get a scope for this? I don't have one...
« Reply #4 on: November 10, 2021, 11:03:38 am »
Thanks, that's what I need, just a bigger one with same resolution.
Offline Boscoe
« Reply #5 on: November 10, 2021, 04:24:39 pm »
It’s difficult, I have the data sheets for the A and C variants and there’s a few subtleties to the interface including some which are programmed for the application. I will be at my computer tomorrow and can send some print screens of the pin out but I cant share the data sheets as they are under NDA. I can also let you know what to look out for. I think youre definitely going to need some FPGA between this driver and the new display. It’s not an easy plug and play project.
« Reply #6 on: November 10, 2021, 04:31:01 pm »
Thank you Boscoe.
FPGA is beyond my skill level  :-//
So will it be easier to take the signal before the 358762G, from the host?
Offline ArsenioDev
    • DiscountMissiles: my portfolio and landing page
« Reply #7 on: November 12, 2021, 10:04:56 pm »
I'm very interested in those pinouts too please!
« Reply #8 on: November 18, 2021, 02:59:38 pm »
Here's the datasheet of a similar model ECX334AF, I don't know what's the difference between them.
Are there any off-the-shelf replacement for it?
« Last Edit: November 18, 2021, 03:06:17 pm by Logan »
The following users thanked this post: ArsenioDev
Offline ArsenioDev
Re: (Datasheet added)Need help, Replace EVF micro-OLED with a big one
« Reply #9 on: February 07, 2022, 04:47:32 pm »
Oh hell yeah, been lookin for a datasheet like this for AGES. Thanks a ton!
Ok, looks like it's bog standard RGB 888 or YCbCr88, so in theory if you tap those signals and break them out, should be pretty trivial to port out to a different display.
« Reply #10 on: February 08, 2022, 05:22:10 pm »
Thank you!
Could you tell me a little bit more details, like how can I archive this? Sorry I'm not as experienced as you guys...
