Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Power supply fails to start
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Power supply fails to start (Read 1912 times)
itdontgo
Regular Contributor
Country:
on:
March 09, 2016, 11:46:29 am »
I'm a little baffled by this issue. Initially this prototype board we have worked fine. It then appeared to struggle to start but touching the soft start capacitor made it run. Eventually though it would not reliably start regardless unless you started it at 30V! This is the same circuit we have built many times although in the past it has had a different PCB layout. The main supply chip is the AOZ1284
http://www.aosmd.com/res/data_sheets/AOZ1284PI.pdf
When it runs it's a nice power supply with low noise. All of the main parts have been changed. When we changed the coil it worked perfectly but this had nothing to do with the coil.
We accidentally knocked the boot strap capacitor off. It always starts with this removed, however, runs noisily at high voltages but does not take excessive current.
I'll be honest I don't understand the issue. The general PCB layout is good when it runs.
Logged
https://priory-electronics.com/
https://alarm-diallers.com
Apollyon25_
Regular Contributor
Country:
Re: Power supply fails to start
Reply #1 on:
March 13, 2016, 08:59:48 pm »
Sounds like you took a perfectly good design and changed too much of it.
Schematic, PCB??
You have all the keys to answer this - you've mentioned many of them.
Logged
rx8pilot
Super Contributor
Country:
If you want more money, be more valuable.
Reply #2 on:
March 13, 2016, 09:15:17 pm »
post the schematic and all layers of the pcb. It's almost always the
layout. Few people give enough credit to the impact of parasitics of the PCB. They will stop any converter.
Sent from my horrible mobile....
Logged
Factory400 - the worlds smallest factory.
https://www.youtube.com/c/Factory400
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
