Author Topic: Fake Coilcraft on eBay  (Read 4985 times)
Offline BudTopic starter
« on: November 30, 2014, 05:34:30 am »
Bought 'Coilcraft' RF transformers on eBay, upon arrival it was clear they are counterfeit. Does not take much to see which one of the two in the attached photo is a fake. Also the color spots marking on the outer top of the package was not exactly as on the originals.
Offline Paul Price
Re: Fake Coilcraft on eBay
« Reply #1 on: November 30, 2014, 01:00:33 pm »
I donno, looks like a lot of baluny to me.
« Last Edit: November 30, 2014, 01:06:52 pm by Paul Price »
Offline dannyf
« Reply #2 on: November 30, 2014, 01:09:39 pm »
You should assume anything on eBay is counterfeit unless proven otherwise.
Offline G0HZU
« Reply #3 on: November 30, 2014, 02:12:55 pm »
Yes, looks like a windup to me too...  ;D
Offline Yago
« Reply #4 on: November 30, 2014, 02:20:47 pm »
Core blimey this is bad! :P
Offline JoeO
  • I admit to being deplorable
« Reply #5 on: November 30, 2014, 03:38:44 pm »
And how can you prove it is legitimate unless you buy it?
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
Offline nukie
« Reply #6 on: December 04, 2014, 03:59:47 am »
Name and shame please.
« Reply #7 on: December 04, 2014, 04:25:16 am »
I think it's a mu-stake to buy things on ebay if you're looking for reliable and genuine.
Yes, no ebay anymore for known manufacturers parts.
It is not obvious from the photo but the wires on the fake transformer are soldered to the pads, whereas on the genuine one they are cold welded. So that means the windings on the fake transformer may disconnect from the pads during soldering the transformer onto a PCB.
Offline jlmoon
  • If you fail the first time, keep trying!
« Reply #8 on: December 04, 2014, 05:42:55 pm »
Ferriteful.  I'd be in hysteresis if I got such an improper transformation of parts.
 :-DD  Awesome play on words!
Recharged Volt-Nut
Offline Monkeh
« Reply #9 on: December 04, 2014, 08:46:20 pm »
Assuming the solder melts at such a low temperature. There are high temperature alloys specifically for this..
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #10 on: December 04, 2014, 10:03:02 pm »
Although, high temperature solders are either really high (e.g., silver solders -- brazing, really) which seems unlikely, or soluble in regular solders (e.g., 90-100% Pb).  Zn alloys have higher melting points, but AFAIK, don't touch electrical components, and wouldn't make good joints if they did (due to the solubility in tin but not lead*, and higher reactivity demanding a stronger flux).
So, that would just be a matter of soaking the joint for longer -- automated paste reflow might be okay (not too much dissolves, merely leaving a joint with a pasty appearance), but hand soldering with a little too much dwell and a little too hot iron will easily carry that risk.
*Yes, zinc floats on top of lead.  This was used to extract silver (which is more soluble in zinc and therefore partitions into it) from lead before electroplating became the preferred purification method.  However, enough tin will dissolve both (just as enough alcohol will bring water and oil together), but probably leave you with something unfit for soldering.  This has been your Random Fact of the Day. :P
Seven Transistor Labs, LLC
