my guess ..... using such Vref, it allows to operate without antenna with reasonable accuracy. when it transferred to the place without gps signal, after it takes some time to adjust itself.
location of Vref under OCXO can , influence by temperature, so it indirectly warm up, decreasing affect of environment temp. fluctuation ... ; I would say it a good design.
if possible i would suggest a little mod of shielding ocxo by additional thermal isolation, foam , cellulose, anything to minimize heat dissipation to environment, it will minimize jitter and save some energy, increase quality of adjustment.
when turn on - standalone oscillators usually stop drifting about 2 weeks ; after power interruption , a few hours. for Vref , a bit worse - initial drift a few hundred hours, and can be jump in Vref after power interruption.
tl431 extremely unstable comparing to MAX , and it nothing to do with output noise, stability of Vcorr has to be fraction of millivolt
