Author Topic: PCI Express GPIO solution  (Read 15134 times)
Offline iceisfunTopic starter
« on: November 19, 2013, 04:24:39 am »
Does anyone here know of a good PCIE GPIO card?
I would like a card with a port on the back that goes to a gpio breakout board.
Offline Jon86
Re: PCI Express GPIO solution
« Reply #1 on: November 19, 2013, 06:55:47 am »
Do you mean GPIB? If not, what kind of port are you looking for? There's no such thing as a GPIO Port, as far as I'm aware.
Death, taxes and diode losses.
Offline kxenos
  • Country: gr
« Reply #2 on: November 19, 2013, 07:04:01 am »
I use these http://www.icpdas.com/root/product/solutions/pc_based_io_board/pc_based_io_board_products.html#PCI.
Pretty robust. about 2 boards broken for about 130 PCs for 12 years.
alm
  • Guest
« Reply #3 on: November 19, 2013, 07:56:20 am »
Unless you need the extra speed or lower latency, a GPIO interface with USB connection (eg. Labjack) may be a cheaper solution.
Online amyk
« Reply #4 on: November 19, 2013, 12:53:58 pm »
How many bits of GPIO do you need, and how fast?
Offline penfold
« Reply #5 on: November 19, 2013, 01:16:14 pm »
Something like the amplicon PCIE296 sounds like its what you're after.  At 199GBP its cheaper than most Labjack offerings for higher numbers of IO lines (not that a single labjack would give you 96 lines)
If you were on regular PCI then the prices are much cheaper
Offline jeremy
« Reply #6 on: November 19, 2013, 01:36:16 pm »
You should buy one based on software development practices that you are comfortable with. For example, the NI DAQ cards are nice (but expensive), I really don't like labview though. Good thing they provide ANSI C libs too. I have seen a bunch of cards which were supposed to be used with visual basic (yucky!), if that is not your flavour then don't spend your money.
« Reply #7 on: November 19, 2013, 06:22:08 pm »
That is awesome, exactly what I am after.
Thanks for the tip!
