Author Topic: Symmetrical power supply from a single rail  (Read 5543 times)
Offline TrickyNekroTopic starter
  • Country: gr
  • Drinking Frappé on the way to Isomnia!
    • Youtube channel, electronics and more ;-)
« on: October 01, 2013, 06:40:43 pm »
Hallo again with another question,
This of course is related to some extent to my previous one but that´s not the point.
I need some pointers here only, I need to build a symmetrical power supply, really low currents 100 - 200mA
worst case scenario. The outputs can be whatever from +/- 7.5V to +/- 12V, I will use linear regulators after
the switching one. The extra rails will be powering precision op amps so the need for linear regulators is mandatory.
The problem is that I don´t know what to look for, as in the name of the topology, or if
someone did it before he/she can suggest a part number.
I am not really sure about the input voltage that I want. But it can range from +5V to 12V, unfortunately, I
can not be sure yet, there are many more things to consider.
So, the question? What am I looking for? Sure enough it´s a DC/DC converter but I get lost sometimes with
topology names! And a IC suggestion will be much much appreciated!!! :D
BTW there is not really a space restriction, I am building this for a robotic platform, meaning that I don´t really
need a one chip solution. It can be two also. And I don´t have a problem with using inductors, I´d rather stay
away from charge pumps, I don´t really like them, they don´t really have a high enough current output and
the voltage swing can be terrible, so no thank you.
If you are an engineer and you are not tired...
You are doing it wrong!
Offline Alana
Offline Skimask
Re: Symmetrical power supply from a single rail
« Reply #2 on: October 01, 2013, 08:39:40 pm »
Just got done building a few of those.
LM2588.
4v-6v input, +12v/-12v output @ ~300mA.
It's all in the datasheets.  Works like a champ if you follow the directions.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline dannyf
« Reply #3 on: October 01, 2013, 10:11:56 pm »
Most dc/dc converters can be configured to produce a negative voltage.
  • Country: gr
« Reply #4 on: October 01, 2013, 11:13:30 pm »
https://www.eevblog.com/forum/projects/layout-review-inverting-buck-converter/ <-- something like this?
Yes, why not, but! You got a small but potentially big problem with your design. I don´t know if it´s a coupled inductor you used,
but if not, you have to remove the ground plane below the inductor and a little bit larger area below the
inductor, plus maybe more the inductor a little bit further away from the other components.
You have to provide the inductor with a magnetic field return path, it´s almost like a must. Right now it´s like inductively heating
the copper below, losing a lot of efficiency and potentially creating noise sources!
This not me telling you this, these are Maxwell´s equations. The magnetic field is formed around a closed path. Eventually it will
close sure enough, but you are effectively killing the "nominal" value of your inductor, usually by a lot.
But anyhow that´s a friendly advice from someone who studied physics  :P
LM2588.
Heh, good one! thanks! But the circuit suggested in the datasheet can be tremendously improved with a higher though
part number. But really good find thanks!
Hey, come on, give me some credit  :P
I´ve worked with MC34063 before, but I don´t have a vast knowledge on DC/DC converters. I am more asking about
successful romantic stories  ::)
Anyhow, thanks for your time and replies!
Best Regards,
Lefteris, Greece
« Last Edit: October 02, 2013, 01:05:50 am by TrickyNekro »
Online tom66
« Reply #5 on: October 01, 2013, 11:21:43 pm »
I've used a DC-DC buck with a negative charge pump running off the switching waveform. Works acceptably up to 30~40mA but the output is equal to the input minus a few diode drops, it's not regulated, and you need to ensure a minimum load on the positive rail OR choose a converter which never enters pulse skip mode like one designed for audio systems. (Constant switching frequency = easily filtered.) There's also a very nice LT part with dual boost/inverting converters I've used before, constant frequency if you choose the right version but it's only available in a tiny DFN package which is a pain to work with. LT3471 from memory.
  • Country: gr
« Reply #6 on: October 01, 2013, 11:32:52 pm »
Thanks for the suggestions, especially the LT part seems promising although more advance, I would prefer to
use something more easy at the beginning. Still, the double feedback is really a good feature! These packages
can really be a big pain especially when you are building your own PCBs at home, but as long as they are not
BGA everything is possible! :-)
And yeah, I kinda really hate to use charge pumps. They are a good solution when you only need a reference,
or just power something small but not for my case, plus I consider them messy. You are depending a lot on these
capacitors. I need really stable and reliable rails, I have to use linear regulators after the switching ones.
