Author Topic: My try at Daves DC load? opinions  (Read 18848 times)
Offline ahnuts72Topic starter
Re: My try at Daves DC load? opinions
« Reply #50 on: May 10, 2013, 02:42:23 am »
Sure enough it was from the fan
unplugged it and straight to a flat line.
Thanks for all you guys help.
Gonna add some filtering try to get it
right and then maybe make a new board.
« Reply #51 on: September 29, 2013, 09:39:34 pm »
Ok finally got around to building a filter for the fan noise now much better.
Ran it on the power supply at 1 amp for 30 min transistor and heat-sink
got warm but worked great.
Went to shut everything down and thought I would get a few pics.
First one is comparison of meter and display,second one is before
the filter third one is after.
Offline Spikee
« Reply #52 on: September 29, 2013, 09:58:17 pm »
You could use an isolated low power dc dc converter for your fan (also isolate the pcb space).
Freelance electronics design service, Small batch assembly, Firmware / WEB / APP development. In Shenzhen China
« Reply #53 on: October 02, 2013, 02:31:29 am »
I've got rid of the noise on the supply rail and no oscillations so I think I'll leave it alone.
May make a new board with the filter on it instead of spliced into the feed for the fan.
Sent from my Nook HD
