My latest project is more software than hardware based - a welcome change from puttering away in the lab all day!
It's a simple bandscope - originally running on a Raspberry Pi (with an optional touchscreen) and using a USB RTL-SDR dongle as the detector - simple enough: but I was unhappy with the software availability so I said "F***" it and made my own.
(note, that bottom button is just a placeholder to allow me to access the debugger script on-the-fly!)So far it works decently well - it's still running on dummy data rather than actual spectral data but that side of things should be fairly simple to implement with the RTL-SDR Wrapper: though this might affect the framerate depending on the sweep distance!
It's written in Python(2.
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
and uses WxPython (a wrapper for the WxToolkit) for the GUI - and will hopefully be extensible to almost any SDR provided it has a python wrapper.
The question is: what sort of features should I implement in it?
So far it has:
-USB RTL-SDR Support
-Spectrum display (frequency sweep)
-Max/Min signal strength indicators
-Frequency indicators (highlights top 5 peaks)
-Waterfall display (frequency sweep / time)
-Hybrid (combined) Spectrum/Waterfall display (one above the other)
-Custom spectrum/waterfall palettes
-Zoomable Displays
-Optional Hardware controls (i.e an optocoupler for a dial and keypad digit entry)
-Multi-Platform (tested on windows and linux)
What other things would people like to see?
Some things I've already considered are:
-Grid overlay on the displays
-Distance between peaks/peak measurements
-Adjustable Noise Filters (might be hard on performance!)
-Audio-receive
-this would required adjustable bandwidth controls as well
-Audio Recording
-Trigger level control (don't display any signals weaker than a setpoint)
-Data logging (log the spectral data over time)
