Author Topic: Class D amplifier as four quadrant Power Supply - Stupid idea?  (Read 1981 times)
Offline ulwurTopic starter
Hi! I have searched the forum for a topic like this but haven't found anything useful.
 I have an idea.. Trying to design a 4-quadrant power supply for my bench, and got the idea to use a Class-D amplifier circuit for the output stage to minimize the losses.
Is this a good idea? Will it work? Have it been tried?
Most of the time the supply will, ofcource, be working like a simple Buck voltage regulator.
Ideas on how to create the PWM waveform? The resolution of the PWM would have to be something like 6000 steps to create +-30 volts with 10 mv resolution. The input to the PWM Circuit is analog so I cant use a Micro to create the PWM signal.
Is it too complicated? Am I Better off with a traditional Class AB amp with switching buck pre-regulators to keep the losses manageable?
The following users thanked this post: krayvonk
Offline bitseeker
Re: Class D amplifier as four quadrant Power Supply - Stupid idea?
« Reply #1 on: July 18, 2019, 01:31:06 am »
A four-quadrant power supply is able to sink as well as source power. In other words, it's both a power supply and an electronic load, depending on which quadrant it's operating in. So, you'll need to understand how both types of equipment work.
A Class-D amplifier is a switch-mode power supply (SMPS). Search for that and you'll find lots of information. Note that they are more complex than linear power supplies.
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: July 18, 2019, 01:47:52 am »
Amplifiers generally are designed to supply predictable loads, not wildly varying ones.
Online David Hess
  • DavidH
« Reply #3 on: July 18, 2019, 02:13:08 am »
A bipolar (positive and negative, not transistor type) output class-D amplifier can make a great output stage for a 4 quadrant power supply with the usual caveats about noise and stability.  Higher power units do exactly this when high power density is required.
Just beware that when operating as a load, the power is transferred to the internal power supply which may rise out of bounds if not controlled.
The following users thanked this post: ulwur
