Yesterday I had the crazy idea of putting a radio transmitter on a rotating platform. This way, in my head, the transmission of data to the ground platform is completely decoupled.
I mean the ground platfrom doesn't rotate, it should have a radio receiver and should just needs to provide power to the rotating platform via a rotating decoupled ring. This ring is good for providing power, but too noisy on data, because each electrical contact on the rotating ring does crawl, and this produces electrical noises!
What I wonder is ... if the rotating platform does need to rotate at 6000 turns/min, will it produce any problem to the electromagnetic signal received on the ground platform?
Supposing I will use Amplitude Modulation for transmitting information via a radio carrier wave. On the rotating platform the carrier wave will be around 600Mhz while the signal strength of the carrier wave will vary in proportion to that of the digital message signal being transmitted.
Say, V1 for the "0" logic, and V2 for the "1" logic.
Will it work? Or will I see any weird effect on the ground receiver due to the the rotation of the transmitter?
Thanks
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
