The amplifier still has not been buttoned up. When running it for several hours, I noticed that the power transformer gets fairly warm to the touch. I have nothing to gauge it on. Our AC mains is running 122-123V. Seems when I was growing up with my analog meter, the mains was around 110. How accurate that old meter was, or my memory, hard to say. They spec'ed the amplifier to run from 120-105, or 112.5 +/-7%ish. Seems tight. They claim 160W draw, guessing full volume. They fuse it at 3.2A, slo-blo. Still has the original fuse.
Looking at the input/output with a scope, it doesn't appear the transformer is starting to saturate with the higher voltage. Tried to run the AC at two voltages to see if it had any effect on the temperature. I am measuring at the top of the transformer where there is a small grove cut into the laminates. Pretty much center. I have no idea what the winding to laminates theta is. In both tests, the amplifier was allowed to run for 3 hours. Same load, volume.... Data was taken using a Kill-o-watt meter.
At 106.3V, power factor was 0.84, 132 VA, 112W, 1.24A, reached 51.3 deg C or a 29.5 rise.
At 122.7V, current draw was 1.46A and it reached 53.7 or 31.9 deg rise.
Guessing that it's normal for it to run this hot.
Over the last week, guessing I have about 25 hours of runtime on it now listening to music and outside of the transformer temps, I'm not seeing or hearing any problems. Started looking at headphones. A friend has one of these amplifiers:
https://www.schiit.com/products/asgard Friend suggests reading the FAQ. You have the artsy-fartsy, touchy-feely people asking questions to the engineering group. It's pretty funny. I like that 0.002% THD vs my dads amp at 0.5%. Dad's old amplifier has a headphone output which is basically tied to the 4ohm output through a 330 ohm resistor to limit the power (11.6^2/330+8 or 398mW). My modern 70's/80's headphones, you have to crank up the volume to hear them and then you are getting into where the amplifier starts to clip. I used to have a set of KOSS HV/1LC which were much higher impedance. I had tacked on a couple of resistors in parallel with the 330s to get me a bit over a Watt when driving the old time 8ohm headphones.
Wow, used asking price for the Koss, I think is more than I paid for them new.
https://www.ebay.com/itm/185916149315Plan to borrow a few different sets from friends to see if they sound any better than my vintage tech. While searching for headphones, came across this site which uses a more analytical approach to doing reviews. I bet they get some flack from audio fanboys...
https://www.soundguys.com/how-we-test/
