Just installed a HVLS fan in my workshop and while the performance of the fan is great, there is an annoying high pitch noise coming from either the motor or the controller.
As you can see, around 14kHz there is a nice line. I have isolated it in audio software and it is the same pitch as the noise when walking around my factory.
The noise comes and goes as you walk around and just tilting your head down can make it go away.
You can only hear the noise when the fan is moving or starting. When idle, there is no noise.
Here is the motor controller board.
Any thoughts on what could be causing this and how to fix?
