Kleinstein,
For R19 / R21, 2ppm tracking ratio arrays are about $1.80 in sot23, pick a ratio that is available that suits you and its easy to route in.
e.g.
https://au.mouser.com/datasheet/2/414/DIV23-1551440.pdfMy understanding is for most of these resistor arrays, the absolute value doesn't matter at all, only that there relative tracking PPM is as close to 0 as possible, lets say better than 2ppm
As such, we don't really need to lock things to the LT5400, there are tens of alternatives in similar packages that meet that specification, All the use cases are relative, not absolute, it doesn't matter that that 25K became a 25.068, so long as all 3 have, or am I inferring that incorrectly. even your recent respin lets us lock down a fixed ration with R19/R21 instead of R8 being a mystery on the old one.
E.g. for the input resistors, we can use another morna array at 2ppm tracking for a 25K input resistance, I know its not the <1ppm of the LT5400, but in reality I feel it should be sufficient, and leaves us alternatives with higher values in the same series.
https://au.mouser.com/datasheet/2/427/morn-795262.pdfYou mentioned an external reference input, plan out the circuit and I can route it,
And finally added some more tabs to make it a bit more rigid, I was more trying to prevent board flex from upsetting the reference,
IMO, flipped around your resistor, now do we want to run current to heat that resistor, and how do you plan to implement it, or do we just use it to measure that resistor, e.g. use the second amp of the MCP6002 to measure the current from the positive reference and amplify it to an ADC or similar.
Edit: Is it not easier to measure the temperature of the array to better than 1C? this seems like it could be the easiest solution, then pulse some power every few seconds to hold it there. I can place an SMD NTC right next to it.
