Hello all,
I have a question for those of you who deal with larger motors.
In terms of simplest control, what is the best choice for large (1-3 hp/ 0.7-2.2kW) electric motors?
I deal with low power motor control most of the time (<200W) where some power MOSFETs and PWM will do the trick. But looking at motors in this larger power class, I've come up with 3 options.
The best option is to buy a ready made variable frequency drive (VFD).
- Single phase AC motors
Don't use them, use a three phase motor running off a VFD powered by single phase.
- Three phase AC motors
Cab be powered from either single or three phase with the appropriate VFD.
- Three phase BLDC motors
Basically the same as a three phase motor except they may have other features such as permanent magnets (synchronous), designed to be run off a square wave rather than a sine and have feedback.
It seems like in this power realm (>750W) DC motors scale up very steeply in cost, so AC is preferable.
Yes DC motors are rarely used in industry these days.
By control I mean speed control and ideally braking.
A VFD can do that and if you can buy another inverter to inject power lost through breaking back into the grid, saving you both power and room for a large breaking resistor
I have a rough idea of control for all three options. My question is, for those of you who have been down this path before, what is the least headache inducing path to take (specifically power supply and drivers) to control this with low voltage logic?
A ready made VFD will have all of that built in, will be programmable and can be controlled by standard analogue or digital signals.
