Can you look for Philips Twin-Eye mouse sensor, like PLN 2030 or PLN 2031. These were Philip's foray into mouse sensors- and they all failed, short lifetime
Then Philips admitted defeat and left the market. I've always wondered what went wrong with them.
I thought the MadCatz RAT 3 would have a PLN2030-Sensor.
Well that was at least wrong for the model i got.
Nevertheless I will post the RAT 3 soon...
Ultimately I found the "Cooler Master CM Storm Inferno" which uses a PLN2030-Sensor.
First of all: What a crazy technology! If someone would have told me that it is possible to detect the reflection of the underground with the laser itself (~5µm active area) I would have told him a maniac.
But actually it´s possible.
Here you can see what´s inside the CM Storm Inferno and inside the PLN2030:
http://www.richis-lab.de/mouse_1b.htmHave fun!
I have a guess what killed the PLN2030 sensors: In most Avago-datasheets you can find warnings regarding ESD sensitivity of the devices. Especially in older mouses there are very big plastic elements below and around the sensor. Additionally parallel to the laser there is always a overvoltage protection semiconductor. But look at the PLN2030:
The sensor has only a small plastic lens which is directly over the hole in the bottom of the mouse. Around the sensor is nothing more. A discharge has only to travel the short way around the lens to reach the metal contacts at the outside of the package which lead directly to the sensor and the laser modules. Parallel to the laser there is only a capacitor which surely has only a small capacitance.
You shouldn't be at all surprised if the PLN2030 often died because of ESD.
