Loading [MathJax]/extensions/Safe.js
Author Topic: Mosfet AC SSR  (Read 19909 times)
Offline OC71Topic starter
Mosfet AC SSR
« on: April 22, 2015, 02:21:04 pm »
Hi everyone,
I would like to make a 10A AC SSR using anti-series mosfets.
Will the attached schematic do the job and if so will it survive without
a heat sink? ---it looks too simple.
Offline wraper
  • Country: lv
Re: Mosfet AC SSR
« Reply #1 on: April 22, 2015, 02:46:33 pm »
Voltage rating of the Mosfets used is too low (200V).
« Last Edit: April 22, 2015, 02:48:34 pm by wraper »
Offline Zero999
  • 0999
Re: Mosfet AC SSR
« Reply #2 on: April 22, 2015, 03:43:27 pm »
What makes you say that? The peak voltage here is only 170V.
EDIT:
To answer the original question. It depends on the ambient temperature. The thermal resistance is 40oC/W and the power dissipated by each MOSFET is 970mW which gives a temperature rise of 38.8oC and the MOSFET has a maximum temperature rating of 175oC but you don't want to go near it.
« Last Edit: April 22, 2015, 03:56:51 pm by Hero999 »
Offline wraper
  • Country: lv
Re: Mosfet AC SSR
« Reply #3 on: April 22, 2015, 04:39:56 pm »
Take into account mains voltage tolerance too. With a tiniest transient, peak voltage will easily exceed 200V. Note that there is RMS, not peak on the graph.
« Last Edit: April 22, 2015, 04:53:48 pm by wraper »
Re: Mosfet AC SSR
« Reply #4 on: April 22, 2015, 06:21:53 pm »
Is the rest of the circuit OK? Can it be done this easily? it looks too simple.
Offline eneuro
Re: Mosfet AC SSR
« Reply #5 on: April 22, 2015, 07:00:03 pm »
It depends what you plan to do with this 1.2kW heater  ;)
Look at page 2 in vom1271t datasheet where at 30mA IF you have ONLY Isc= 45uA (0.045 mA) , so you need estimate its maximum switching speed.
Even for  ON/OFF probably I'd add also AC mains zero crossing detection and while this  vom1271t has such weak gate drive current controll mosfets switching in zero crossing.
But ok. I didn't used this  vom1271t while sometimes difficult to source, however I used 800V-1000V AC mosfets switch but with optoisolated gate driver PSU and cheap $1 TLP350F  2.5Amax, which means 2.5A/0.000047A~50000 times biger AC mosfets switch gate driver current  ???
I do not like switching 1kW with such low gate current like 47uA without zero crossing detection, but maybe someone else used this low current vom1271t sucessfully, so it could be nice to see how it works.
Test it and tell us if those quite nice (and expensive) 8mOhm 200V mosfets survived given switching frequency  :popcorn:
« Last Edit: April 22, 2015, 07:40:39 pm by eneuro »
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
Offline dom0
Re: Mosfet AC SSR
« Reply #6 on: April 22, 2015, 07:28:43 pm »
Uhm... has this any specific sense? A COTS SSR will be cheaper and likely more reliable... the big ones are almost all CAT III and very tough.
Offline eneuro
Re: Mosfet AC SSR
« Reply #7 on: April 22, 2015, 07:45:27 pm »
For heater triac BTA16 a few resistors and MOC3041..MOC3043 with built in zero crossing and... bigger radiator to ensure good heat dispation that is all for resistive heater ;)
Re: Mosfet AC SSR
« Reply #8 on: April 22, 2015, 08:03:36 pm »
Thanks for the feedback everyone.
I would like to use mosfets for the experience.
I cannot find a mosfet >200V with a RDSon low enough to operate without a heatsink.
@eneuro, -- I think I will play safe and use the driver you mentioned.
Driver:
http://www.ebay.ca/itm/191554680124?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Mosfet:
http://www.aliexpress.com/item/IRFP4668PBF/1641388922.html
Offline wraper
  • Country: lv
Re: Mosfet AC SSR
« Reply #9 on: April 22, 2015, 08:18:07 pm »
I would suggest to not get mosfets and optocouplers from China. There could be anything inferior hiding inside the part.
Offline eneuro
Re: Mosfet AC SSR
« Reply #10 on: April 22, 2015, 09:38:17 pm »
There are plenty of them-I choose TLP351F while it is usable for other projects too, but you will need optoisolated PSU, however in tests you can use 12V battery with lets say 27R you will get around 0.5A gate current.
It looks like that ebay folks earns a lot on those TLP351F 3$ for this thing?  :o
TME is not the cheapiest, but they have is for less than $1 - $0.80 when you buy 10  ;)
http://www.tme.eu/en/katalog/?idp=1&search=tlp351&cleanParameters=1
Also if you buy there 10 those mosfets there IRFP4668PBF than each is around $6, so 2 times cheaper  :o
http://www.tme.eu/en/katalog/#search=IRFP4668PBF&s_field=accuracy&s_order=DESC
Shipment in TME costs me less than $4, so usually for prototypes looking chips in TME.eu first  ;)
UPS: Didn't notice than those China IRF's is 5 pieces...
Mised also this: Estimated Delivery Time: 15-34 days (ships out within 5 business days)  :palm:  :--
I've got things from TME.eu usually 2nd day after order  :-DD
« Last Edit: April 22, 2015, 10:29:27 pm by eneuro »
Re: Mosfet AC SSR
« Reply #11 on: April 23, 2015, 06:13:38 am »
@ eneuro. TME shipping cost to Canada is 17.90 EUR plus duty.
Why would I need an opto isolated supply for the driver. Isn't the input isolated
already?
« Last Edit: April 23, 2015, 06:24:16 am by OC71 »
Offline Zero999
  • 0999
Re: Mosfet AC SSR
« Reply #12 on: April 23, 2015, 07:52:23 am »
It's not practical to use such high voltage MOSFETs. Open up any mains powered switched mode power supply and you'll find the MOSFETs will be rated to 400V in the 230V world and 200V in the 120V world. If it's an industrial unit you may find IGBTs rated to 600V but nothing like the voltages shown in that graph.
If there's a high voltage spike, the MOSFETs will simply go into avalanche breakdown and will not be harmed, as long as the energy in the spike is not too great. If it's an issue, there are this things called  metal-oxide varistors, which can be connected in parallel with the MOSFETs to will absorb some of the spike and provide some degree of protection.
Offline eneuro
Re: Mosfet AC SSR
« Reply #13 on: April 23, 2015, 08:15:10 am »
already?
I meant galvanic insulated/floating power supply for AC mosfets switch gate driving, but as I wrote battery is good starting point to test this thing.
You can use even 9V battery with lets say 20W mains load (small light bulb), while it should switch on those bulky mosfets with decent RDSON, but for higher loads 12V or sometimes 15V even better to lower down mosfets RDSON.
http://forum.allaboutcircuits.com/threads/floating-power-supply.10345/
A floating power supply can aso be imagined as a battery.
Offline Zero999
  • 0999
Re: Mosfet AC SSR
« Reply #14 on: April 23, 2015, 10:12:37 am »
Rather than using an opto-isolator, you could inductively or capacitively couple the control signal to the MOSFETs.
The pulse transformer needs to be rated to give adequate insulation between the primary and secondary and the capacitors need to be Y1 rated. The value isn't important but should be low enough to provide a high impedance to 60Hz so the leakage current is kept to a save level: 100pf should be more than enough.
« Last Edit: April 23, 2015, 10:15:22 am by Hero999 »
Re: Mosfet AC SSR
« Reply #15 on: April 23, 2015, 10:36:32 am »
Thanks everyone.
@ Hero999
 -- What is the purpose of R1?
 -- Does it matter whether RL is on the Hot or Neutral side?
Offline Zero999
  • 0999
Re: Mosfet AC SSR
« Reply #16 on: April 23, 2015, 10:56:39 am »
1) R1 discharges the gate-source capacitance when the control signal is switched off. Without it, the MOSFET will take a long time to turn off or may never turn off.
2) No. Why would it? The MOSFETs just act like a switch in series with the load. Generally the phase conductor should be switched for safety reasons but in this case MOSFETs should not be relied upon to safely isolate the load from the supply.
Re: Mosfet AC SSR
« Reply #17 on: April 23, 2015, 11:28:21 am »
@ Hero999
Thanks for your input.
Why 200KHz control? Why not 60Hz mains frequency?
Offline dom0
Re: Mosfet AC SSR
« Reply #18 on: April 23, 2015, 11:35:05 am »
- Smaller pulse transformer (at 200 kHz you can use "standard issue" pulse xformers for SMPS)
- Cgs + R1 give a RC time constant for turn off. At 60 Hz this time constant must be unreasonably long, which leads to very slow turn off speeds and eventual thermal issues for the FETs. With a 200 kHz control signal the time constant can be much shorter.
I still don't get why you guys try to build your own SSR  :-//
Offline Zero999
  • 0999
Re: Mosfet AC SSR
« Reply #19 on: April 23, 2015, 11:46:19 am »
That's true for the pulse transformer version but what about the one with the Y1 capacitors?
@ Hero999
Think about it.
What do the capacitors do?
How does the impedance a capacitor vary with frequency?
As a learning exercise.
Online langwadt
Re: Mosfet AC SSR
« Reply #20 on: April 23, 2015, 12:49:19 pm »
Most SSRs use TRIACs, you can't turn off a TRIAC until the next zero crossing and most cannot handle a half
cycle into  a dead short and a fuse is useless for protecting a TRIAC
With FETs you can turn off in microseconds so you can make it practically bullet-proof
I have seen a few "random off" SSRs but they were ridiculously expensive
Offline dom0
Re: Mosfet AC SSR
« Reply #21 on: April 23, 2015, 01:31:14 pm »
Most SSRs will be used for ohmic loads where fusing is not really an issue. Generally speaking short circuits are not a really an issue for larger SSRs (25+ A) in household circuits, since short circuits currents are generally rather low (200-400 A). Smaller SSRs like for example a Sharp S202S02 have 10 ms peak currents of something like 75 A, so you need to pay a bit of attention here.
Fusing SSRs for inductive loads is much harder and yes, it might even be impossible to find a fuse that provides the necessary protection in some cases. In those cases I'd just go for the next larger SSR and be done with it, or consider wholly different approaches (e.g. using a motor driver instead of a SSR to switch a motor, or using classic relays if switching is infrequent etc.)
Offline eneuro
Re: Mosfet AC SSR
« Reply #22 on: April 23, 2015, 03:48:36 pm »
Whet you have 200kHz and toroid or small transformer than you can easy make a few mA 12V-15V PSU and power up TLP351F, than another few mA for optoisolator diode and you have really fast ON/OFF switching  ;)
In some projects use TLP351F with +/-12V (yep it is possible make such PSU for this optoisolator) for faster turning OFF with negative voltage rather than by 0V  8)
When you use 220k resistor on those two AC mosfets with this IRF http://www.tme.eu/en/Document/7f58240ac39dafede53e055f51f59c8f/irfp4668pbf.pdf  total gate charge: 2*Qg= 2*162nC= 324 nC,
C=Q/V , for 12V we have: C= 27nF , so you get RC ~6ms (http://www.referencedesigner.com/rfcal/cal_05.php ) :o and when we multiply this by lets say optimistic 2x RC ~14% of 12V ~1.6V (probably below gate threshold voltage for this IRF), than we have >10ms for AC SSR switch OFF without high current gate driver using bloody 220k resistor  :palm:
I use 100k gate resistor, but only as additional pull down with TLP351F or even 0.8Amax BC337/BC327 totem pole discrete driver.
Offline Zero999
  • 0999
Re: Mosfet AC SSR
« Reply #23 on: April 23, 2015, 05:00:50 pm »
I agree it would be slow but no worse than a optically coupled MOSFET. There is no reason why the gate resistor couldn't be decreased if switching speed is an issue.
It's good this has been brought up - I need a high speed (or not so slow) SSR for another project but it's not mains. I've just tried the capacitively coupled MOSFET SSR on my bench but used 15k for R1 and increased the frequency to 1MHz. I used the old 2N7000 (yes I know it's not suitable for mains and has a low gate capacitance) and was able to switch the MOSFETs at 17kHz. The main issue I can see with higher frequencies is RFI but that can be solved with capacitors and ferrite beads.
I agree the ultimate solution to switching speed is to use a transformer or capacitively coupled isolated power supply to power a proper MOSFET driver.
Re: Mosfet AC SSR
« Reply #24 on: April 23, 2015, 07:04:13 pm »
Thanks for the info everyone. I am currently trying to soak it in.
Meanwhile, with my limited knowledge is it possible we have gone full
circle from the VOM1271T  driver which has integrated turn-off
circuitry.
