Author Topic: To Modify 50Hz to 60Hz, HP 3456A  (Read 16652 times)
Offline nadonaTopic starter
« on: February 11, 2014, 09:59:32 pm »
I have a HP 3456A 50Hz fixed without selectable switch.  European model I think.
It is possible to modify without major expense?
Ha-ha-ha. That's good, too!
Offline dannyf
Re: To Modify 50Hz to 60Hz, HP 3456A
« Reply #1 on: February 11, 2014, 10:44:44 pm »
Do you need to modify it?
« Reply #2 on: February 11, 2014, 11:00:24 pm »
Good question. Yes, I think so.
I don't know exactly but afraid there will be too much heat which may cause
1) fire
and or
2) meter's inside high temperature might affect the meter's accuracy.
and
3) shortens parts life.
No?
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: February 11, 2014, 11:19:50 pm »
all that switch does i tell the integrator to adapt timing to coincide with the power line crossing.
Offline dannyf
« Reply #4 on: February 11, 2014, 11:51:13 pm »
-No?-
read the schematic to be sure.
« Reply #5 on: February 12, 2014, 12:52:28 am »
So ignore the frequency? Sorry, I am not clear.
-No?-
Which part of the schematic should I read?  What to make sure?
Thank you
« Reply #8 on: February 12, 2014, 06:47:46 am »
More questions popped up.
I turned on the meter and
it shows ----- instead of numbers.
Pressed the test button and shows fail no 3.
Manual eventually pointed to 8.B.35: 50Hz or 60Hz?
I opened the case and measured the frequency at the crystal. 4.875MHz(50Hz)
So just exchanging with the 5.85MHz(60Hz) crystal will solve the problem?
Any European 3456A users? Could you take a look at the back of your meter if it looks like my meter?
Thank you in advance.
« Last Edit: February 12, 2014, 07:53:23 am by nadona »
Online Bill158
« Reply #9 on: February 12, 2014, 01:49:35 pm »
The 3456A will work on 50 or 60Hz frequency just fine with no overheating.  The issue is with the common mode rejection of the 50 or 60Hz, depending upon the power line frequency.  This is accomplished by changing a crystal (A30Y1) on the A30 board.  The 50Hz crystal is P/N 0410-1225, 4.875 MHz, and the 60Hz crystal is P/N 0410-1226, 5.85 MHz.  The HP/Agilent website shows the parts to be obsolete.  These are a pretty standard package so I would guess that you could find a replacement somewhere.  I have done this many times depending upon where were we installing the equipment.  I am not sure why HP just didn't include both crystals in the 3456A, having the unused one in a holding clip, so that you could just change the frequency by installing the correct crystal.  Good luck.
Bill
Offline mweymarn
  • Callsign: DL2VW
« Reply #10 on: February 12, 2014, 03:08:58 pm »
I did the conversion from 60Hz to 50Hz some months ago. The package is HC-50/U, not the common HC-49/U type. The HC-50/U has thicker pins, these are needed to make proper contact with the PCB-mounted holding clip.
I had the crystal custom made. For people located in Europe I can highly recommend these people (no affiliation, just a happy customer):
KRYSTALY, Hradec Kralove, a.s.
Okruzni 1144
500 03 Hradec Kralove
Czech Republic
krystaly@krystaly.cz
Note that my 3456A worked fine with a line frequency of 50Hz, even before I replaced the crystal. Using the correct clock frequency is important only for achieving the specified rejection of noise at the power line frequency.
I believe that the 34401A measures the mains frequency at turn-on and sets its internal timing accordingly. Not sure about the 34410A.
Best regards,
Martin
« Last Edit: February 12, 2014, 03:32:15 pm by mweymarn »
Online tszaboo
« Reply #11 on: February 12, 2014, 04:07:04 pm »
Interesting that they actually bothered to make a version for 50Hz. We bought an Agilent 34410A recently and I had to write some software for it. Turns out that all the integration timing is based on 60Hz no matter what the power line frequency is.
U902 in the 34410A will sense the frequency for you (judging by the sch). timing is different, where you plug your DMM into the wall.
« Reply #12 on: February 12, 2014, 06:22:47 pm »
Anybody know where to buy the crystal in US?
Being made by HP, the popular retailer like Digikey doesn't carry that specific frequency crystal, I think.
Thank you for all the information you provide.
<Edit - added> I want to make sure .... So there is no difference other than the crystal's frequency between 50Hz and 60Hz?
« Last Edit: February 13, 2014, 04:14:25 am by nadona »
Offline Shock
« Reply #13 on: February 14, 2014, 03:08:21 pm »
Make sure you check for the correct fuse as well.
Can you understand all the markings on the back of the unit?
Offline dannyf
« Reply #14 on: February 14, 2014, 03:14:23 pm »
Those are pretty odd frequencies and it is not likely that you will find them widely available.
One potential solution is to use a programmable PLL to generate that frequency. A lot more choices available there.
A simpler solution, not likely successful however, is to see if you can find easy multiples of those frequencies and run the signal through a divider.
Online PA0PBZ
« Reply #15 on: February 14, 2014, 03:40:08 pm »
They list it, FWIW: http://www.lintechcomponents.com/product/011368125/04101226585MHZ/28480
Otherwise I think mweymarn should have a spare one?  :)
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #16 on: February 14, 2014, 04:00:32 pm »
Nadona, I have a 60Hz 3456A that I would like to convert to 50Hz. Perhaps we could exchange the crystals, so we both get what we need? Send me a PM if you are interested. :)
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #17 on: February 14, 2014, 07:15:39 pm »
I called them and don't have it. Thank you for the URL, though.
Great this will be THE solutions.
« Last Edit: February 14, 2014, 08:53:37 pm by nadona »
Offline doktor pyta
« Reply #18 on: May 14, 2014, 09:54:11 pm »
Hi guys.
I have 1 spare crystal for 3456A/ 50Hz  and  3 pcs of 3456A/ 60Hz crystals.
Price: 8EUR / each + shipping cost from Poland.
Maybe someone would find this helpful.
Update:50Hz crystal sold.
If someone needs more, please wite an email to http://www.krystaly.cz/en/
Then say them, that you want to order 4,875MHz crystal same as customer "14-03-19 RF Scientific"
It won't cost You a fortune.
« Last Edit: May 16, 2014, 08:43:03 am by doktor pyta »
The following users thanked this post: ipqobk
Offline enz
« Reply #19 on: May 15, 2014, 08:26:08 am »
Hello Bartlomiej,
i am interested in the 50Hz version.
Please let me know how to order.
Regards,
Martin
Offline turbo!
« Reply #20 on: May 15, 2014, 11:33:35 pm »
Bill
I am not sure if continental transfer after initial placement into service was part of expected life cycle. What you're describing is probably only relevant in Japanese market where you have 60Hz in some parts and 50Hz in other parts.
Offline guido
« Reply #21 on: February 05, 2018, 06:27:02 pm »
I'm in the need for a 50Hz crystal. I have a 60Hz crystal available. Before i try the link mentioned here, i would like to know if anybody is in for a swap ?
Got one from http://www.krystaly.cz/en/
Actually you don't want the same one as  "14-03-19 RF Scientific", this has a package with thin leads (HC-49).
You want HC-50/U with plug type pins. But don't worry, they know what is required for the 3456A  ;)
"It won't cost You a fortune."  Correct  :-+
It fixed my second 3456A, the reading are now stable. It used to be 'noisy' with the wrong crystal present. Happy  ^-^
« Last Edit: April 23, 2018, 09:30:37 pm by guido »
The following users thanked this post: dietert1, ipqobk
Offline ipqobk
« Reply #22 on: February 11, 2019, 10:12:26 am »
Thanks for the information, I wrote an email today to the company, I await their response, Paolo
Offline ipqobk
« Reply #23 on: February 20, 2019, 05:34:24 pm »
Ordered two crystal from krystaly. cz for 22 euro included tax and delivery.
Inviato dal mio ONEPLUS A3003 utilizzando Tapatalk
Offline guenthert
« Reply #24 on: January 03, 2024, 01:58:00 pm »
I need to convert a 3456A from 60 to 50Hz and wonder whether someone wants to trade crystals or has a spare 4.875MHz one to sell.
