You have got to be kidding me....
Ok, you will need to use 2 PLLs to get the 336MHz.
PLL #1 to switch from 25/50MHz to 21MHz.
PLL #2 to go from 21MHz to 336MHz.
Otherwise, you will end up with an odd clock frequency value of 336.11111MHz if you use 1 PLL.
Or, if you have a different reference oscillator which can divide cleanly into 336MHz like 27MHz, or 8MHz/16/24/32MHz, 54MHz, 13.5MHz ect...
If you have 3 PLLs in your Cyclone, this project will work fine with any oscillator you already have.
This changes is the sample clock is actually something slightly different like 10.4MHz or 10.6MHz.
Don’t worry, I’ve checked, 24MHz would do it.
Yup, 24 MHz multiplies x 14 to perfectly make 336MHz.
2 PLLs will work fine.
Making a 6 bit counter run at 336MHz will also be not problem.
Since your 336MHz clock will either be ever so slightly slower or faster than the scope's H-sync generated from the 10.5MHz, your final total correction jitter will be an occasional 2.976ns skip in 1 direction.
I haven't a clue, but if you can get a 6 bit counter running at 672MHz, this occasional corrective skip will be down at 1.488ns at a time. Having a code configured fixed phase alignment setting wouldn't be a problem, but you most likely could not get a software controlled one operating at 672MHz unless it's a -6 Cyclone, or just something ingeniously designed.
Clocking a second PLL from the top bit of the 6 bit counter with the low bandwidth loop filter will make that PLL slowly adjust it's rate to align to these skips filtering out any abrupt transition step. That second PLL can simultaneously make you sample clock and video output clock.
Though, if you have a little flexibility on that VGA clock, like running it at 52.5MHz and using a different horizontal sync, front, and back porch values, this figure squarely divides into selecting a single core clock of 105MHz. Where you output the VGA every second clock and sample video every 5th or 10th clock.
