Author Topic: most unreliable power converter circuit?  (Read 799 times)
Online coppercone2Topic starter
« on: August 24, 2024, 07:46:31 am »
out of all the DC DC converters what is the most unreliable circuit topology that is always giving you agita?
have you noticed any trends? i think its flyback
« Last Edit: August 24, 2024, 07:48:04 am by coppercone2 »
Offline dustooff
Re: most unreliable power converter circuit?
« Reply #1 on: August 24, 2024, 11:38:13 am »
flyback converters running free are the worst  :-DD
Trying to persuade a multi winding output to behave as its creator intended, has contributed to the grey hair count.
One thing I have always wondered, is it possible that small transformers particularly multi output that are manufactured down to a price do some aging where they no longer match their original impedance and magnetic performance?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: August 24, 2024, 03:01:20 pm »
In what respect? Design? Repair? Production?
I guess it's free reign to post relevant memes then,
Seven Transistor Labs, LLC
The following users thanked this post: pardo-bsso, MK14
« Reply #3 on: August 24, 2024, 06:13:37 pm »
yo I swear there is something not in the blue prints for this bull shit
The circuits are so low cost, and required test equipment is so high cost, no one will ever find it. And if they do the product count is so high every measure will be taken to hide it under the rug
actually who am i kidding, they probobly can't find it.
I feel like thinking about transformers is unhealthy lol, to me it represents balding
« Last Edit: August 24, 2024, 06:18:03 pm by coppercone2 »
Offline ganfetsic
« Reply #4 on: August 24, 2024, 06:17:19 pm »
The half bridge is a swine, because of the problem of current mode where it goes unbalanced.
Any voltage mode converter is a PITA because if you add load capacitance, it can go well unstable.
The pushpull is a pain because vdrain goes up to 2xvin when the opposite fet turns on, and so youre snubbering will often dissipate a lot due to the high voltage it sees. (unless a complex snubber is done)
SMPS with sync rects is also challenging when there is much secondary side leakage L to ring with the sync FET cds.
Any 400V approx input SMPS which uses bootstrapping (gate drive)  is a pain as they require beautiful layout, which often cant be achieved due to winding tracks around big heatsinks etc.
« Last Edit: August 24, 2024, 06:20:03 pm by ganfetsic »
« Reply #5 on: August 24, 2024, 06:19:13 pm »
the synchronous rectifier is like disguising a uranium centrifuge as a merry go round for young engineers looking for a cool project
I think that one threw 'treez' into orbit
Look at this neat way to reduce heat sink requirements, your boss will love you for it  :-DD
I had someone propose that one to me before. I immediately said its under my skill level, and the senior engineer said hell no (and I usually accept challenging projects). I remembered those circuits where they put capacitors around a rectifier on some test equipment, I also renembered some ranting I was hearing about EMC. I figured it was likely to result in desk banging and deranged psychos scribbling on white board.
« Last Edit: August 24, 2024, 06:23:42 pm by coppercone2 »
Offline ganfetsic
« Reply #6 on: August 24, 2024, 06:22:46 pm »
yes, whenever doing sync rects, always bring up with the sync rects disabled at first, is a good idea.
« Reply #7 on: August 24, 2024, 06:24:24 pm »
Do you think it could do class B EMC on a medium power product (~1kW)?
That was the test bed, then it was supposed to move up to ~30kW, But I think that one had reduced EMC requirements, maybe.But it had to be functional for a while on the smaller product, even if it barely did anything.
« Last Edit: August 24, 2024, 06:30:10 pm by coppercone2 »
Offline jbb
« Reply #8 on: August 24, 2024, 08:14:03 pm »
Not the converter per se, but I think you’ll appreciate it.
As part of an undergraduate university project the class had to make a buck-boost converter. They were provided with a 2-sided board and a library of parts.
One group approached the Teaching Assistant (TA) and said their converter was t behaving right; it would cut in and out of experience wild voltage transients at random.
The TA turned it over and half the components fell out. Turns out they had just put the wires through the holes, bent them over and cut them off. Almost no solder in sight.
« Reply #9 on: August 24, 2024, 08:17:54 pm »
sounds like that was a future boeing leader. they figured out how to save money on the process
but its almost accurate. if you can't solder, that means you can get like 15 meetings in before someone gets a contractor to do it. That should be at least 2-3 weeks of busy calendar. That is like counting how many logs are on your raft, for where those people end up.
« Last Edit: August 24, 2024, 08:21:46 pm by coppercone2 »
Offline gnif
  • Views and opinions are my own
    • AMD
« Reply #10 on: August 24, 2024, 10:05:03 pm »
ganfetsic was banned, this is farringdon again
The following users thanked this post: T3sl4co1l, pardo-bsso, MK14
« Reply #11 on: August 24, 2024, 10:49:48 pm »
lmfao
i remembered it too that he was talking about them a while back
say synchronous rectifier 3 times while looking at your bathroom mirror and he shows up
the circuit diagram looks like a kind of odd trap, when you step on the green pressure plate it grabs your foot
« Last Edit: August 24, 2024, 10:56:26 pm by coppercone2 »
Offline ArdWar
  • Country: sc
« Reply #12 on: August 24, 2024, 10:58:17 pm »
Geez, what's with the flyback slander in this thread? It's so simple hardly anything could go wrong. It's just unfortunate that its simplicity making it the prime target for cheap crap that corners got one cut too many.
« Reply #13 on: August 24, 2024, 11:01:27 pm »
I think their terrible, even the ones inside of CRT monitors, they totally got me off making any of the HV projects a long time ago when it was popular. They all use flyback and I hate all of them
I thought I could make a lifter and a singing arc and that spending all that time taking CRT apart on my lunch was worth it. NOPE  :--
« Reply #14 on: August 24, 2024, 11:09:53 pm »
the data sheet drawing for your chip is rather strange
« Last Edit: August 24, 2024, 11:11:41 pm by coppercone2 »
Offline Kim Christensen
« Reply #15 on: August 25, 2024, 12:40:18 am »
Date Registered: Today at 09:23:58 am
Last Active: Today at 03:47:08 pm
That was fast!   ;D
Your Farringdon detector is top-notch!
The following users thanked this post: gnif, Kean
