Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
AmScope eyepiece issue
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: AmScope eyepiece issue (Read 253 times)
mkahky
Newbie
Country:
on:
August 24, 2024, 11:08:38 am »
I just bought an AmScope SM-3T. The eyepieces do not seem to fit snugly into the scope. In fact they barely rest into the edge of the ocular tubes. What could I be doing wrong?
Logged
jfiresto
Frequent Contributor
Country:
Re: AmScope eyepiece issue
Reply #1 on:
August 24, 2024, 02:40:31 pm »
I have a pair of old Zeiss eyepieces that are ribbed to reach a 30mm outer diameter. I have to turn them to snug them up in eyepiece tubes that expect a smooth and constant 30mm diameter.
Have you measured the O.D. of the eyepieces and I.D. of the tubes?
Logged
-John
Doctorandus_P
Super Contributor
Country:
Reply #2 on:
August 24, 2024, 02:53:01 pm »
On my Amscope (or clone) the eyepieces are mostly round tubes (with some lenses) that slide around 20mm into the tubes sticking out of the scope. It's a loose fit with around 0.5mm of play in it. I guess this is normal and it never bothered me.
Logged
zapta
Super Contributor
Country:
Reply #3 on:
August 24, 2024, 05:12:34 pm »
Same here, it's a loose fit and when I pull my had back after looking through the microscope, they often lift a little and fall back in place.
I think it's normal, but if it's annoying, you can try inserting a piece of paper or something like that.
Logged
magic
Super Contributor
Country:
Reply #4 on:
August 24, 2024, 06:05:36 pm »
I would suggest a piece of something that doesn't shed particles. Insulating or teflon tape, aluminium foil, etc.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
