Jay, the backlight will turn off after 10 seconds no matter what, it's built into the chip.
To answer op's question, see the example circuit in the datasheet, you could hook a wire before the LED and after pressing HOLD for two seconds, the chip will send power through wire which you can detect with a microcontroller or some other chip (some kind of on/off switch etc which will only turn off when the meter is powered off).
