Author Topic: Miniscule springs  (Read 1722 times)
Offline steve30Topic starter
    • Stephen Coates' Homepage
Miniscule springs
« on: September 29, 2013, 07:47:39 pm »
Its annoying when working on something with small delicate mechanical parts and you loose them.
Yesterday I had a tiny spring spring across to another location and now I can't find it. It was probably about 0.5mm wide by about 2mm long.
Does anyone have any ideas for replacing things like this. I'm not really sure where to find tiny parts like this. My device will work OK without it, but it does mean that my mode knob no longer has any clickyness.  :-/O :-BROKE
Offline Astroplio
  • Country: gr
    • Welcome to myrobots
Re: Miniscule springs
« Reply #1 on: September 29, 2013, 08:23:06 pm »
I have seen a spring this small in a DIP switch, perhaps you have something like that in your misc part bin?
Hope you will find something!
George
Offline rollatorwieltje
  • I brick your boards.
« Reply #2 on: September 29, 2013, 08:45:01 pm »
Look for old cellphones, they sometimes use tiny springs as contacts for the speaker.
It may be worth looking on DealExtreme for cellphone parts, like this.
Online Conrad Hoffman
    • The Messy Basement
« Reply #3 on: September 29, 2013, 09:27:21 pm »
They aren't hard to wind if you have some fine piano wire. As above, the next best thing is to find something that has a similar spring.
« Reply #4 on: September 29, 2013, 11:57:10 pm »
I'll have a look in the junk box as I think I have some spare springy switches somewhere.
