Author Topic: Alegbraic Inversion for Other Forum..  (Read 2388 times)
Offline LaserSteveTopic starter
« on: April 17, 2016, 01:04:02 am »
I can't post pics in the other forum.. This is a Algebraic Inverter using Logs... From a old book I have... Will save other guy hours of working this out, I hope..
Will pull the attachment after 48 hours per Educational Use Clause in US law.....
Steve
"What the devil kind of Engineer are thou, that canst not slay a hedgehog with your naked arse?"
I am an unsullied member of the "Watched"
Offline onlooker
Re: Alegbraic Inversion for Other Forum..
« Reply #1 on: April 17, 2016, 01:26:48 am »
"Ir" should be marked next to pin 13 of the IC,  instead of, next to pin 3 of A1.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: April 17, 2016, 09:52:01 am »
No worry, I'd say it's within Fair Use: it's only one page out of a whole book.
Seven Transistor Labs, LLC
Offline Kalvin
  • Embedded SW/HW.
« Reply #3 on: April 17, 2016, 02:19:40 pm »
I agree. However it might also depend on where the server is located how the laws will be applied.
Offline Tomorokoshi
« Reply #4 on: April 18, 2016, 12:40:18 am »
Would that be the Law of Logs?
