Hello all,
let's assume we have a CHIPI-X USB to serial adapter... do you see any potential issue for the serial port if the chip is leaved unpowered but connected to an active RS232 serial port (loops, shadow voltages or currents or any other issue)?
There is a level shifter between the serial and the serial bridge, should it be totally passive if unpowered, do you agree?
