there are two buck regulators in the design, the first supply is powered from 18-36vdc, and has an output load of 100-160mA @ 5v. This is just running some 595 shift registers and a bunch of LEDs.
The second one is supplied by 18-30vdc, and is configured as an analog controlled current source using IS31LT3360, This is 120mA output at full scale. This is driving some LED strings.
The board its going on is a very low volume part, i'm only expecting to hand assemble 100 or so a year. I am trying to keep the total BOM down, but as I am hand assembling there is some benefit to lower part counts.
the LM2574 is about 1.87usd, this was the lowest cost part I could find at digikey that matched the spec
The IS31LT3360 is 0.60usd in singles, this was the first analog controlled buck I could find in a suitable package
im just trying to find inductors in the $1 region for them both, rather than the $5 region parts recommended.
EDIT:
forgot to mention, I will need to pass EMC testing, so I am looking at shielded type inductors.
My current thinking is that I need around 220uH for the IS31LT3360
and around 800uH for the LM2574
I am considering Panasonic ELL-6UH221M, which is rated at 410mA, 220uh and 0.81usd each in singles, and a higher inductance part in the same range for the lm2574
What I don't really get yet is what influence Rdc, Q and resonance frequency have on the choice?
PS: Thanks for the link Bored@work, looks like ive got some reading to do.
