Author Topic: Unipolar Stepper Motor Coil Resistance Specification  (Read 1869 times)
Offline UPITopic starter
« on: February 06, 2014, 11:13:03 pm »
When purchasing a unipolar stepper motor, are the ohms/phase measurement done from the common to one end of the coil or from the two ends while ignoring the common? Seems like an easy question but I am having trouble finding a clear answer.
Motor in question is the 3518x-12 with a coil resistance of 12 ohms:
http://www.linengineering.com/stepper-motors/3518.aspx
My assumption is that the 12 ohm spec is from common to one end of the coil and that you would measure 24 ohms across the entire coil.
Thanks
Re: Unipolar Stepper Motor Coil Resistance Specification
« Reply #1 on: February 08, 2014, 02:32:46 pm »
I received an answer from Lin Engineering:
Unipolar motor resistances are measured from the center tap (common) to the end of the coil. In other words, a motor advertised as a 10 ohm motor will have a resistance of 20 ohms from end to end and 10 ohms from the center tap to the end.
