Smooth, easy to clean surface and 32 rack units worth of 19 inch rack space. Start with the end pedestals; like these
http://www.sweetwater.com/store/detail/ER16/ - the 16 unit rack produces a workbench just over 30 inches high. If you want a higher work surface, use the 20 unit racks; that'll put the top at just over 36 inches. You can get those racks from many vendors under many names, usually much cheaper. They're not fancy, but they're very strong and durable.
Top them with a sheet of tempered glass - check with the folks in your town that make glass storefronts; the glass they use in their doors is just right and you can probably get a blemished piece at a steep discount. Lay that across the tops of your racks / end pedestals and you're done. Is it breakable? Probably, but it's going to require much more force than you'll ever apply. And so easy to clean; solder doesn't stick to glass. Putting a light underneath makes it easy to "see through" PC boards.
Mine was built this way, I've been using it for over 5 years already. It was shipped half way around the world when I moved to Asia, and it made it here with no damage - even through I didn't take the equipment out of the racks for shipping. Outlet strips and such are attached with heavy double-stick tape. Works great.
After a day of hot and heavy soldering iron action, running across the spatters with a putty knive removes all the splats. Then a little window cleaner returns it to bright and shiny again. And it looks great; no more of that plywood and 2x4 stuff for me.
