1. It's fake.
2. Your resistor pushes it into hard dropout, increasing power consumption for some reason. Why not 10kΩ?
3. Your resistor makes it unstable, but you only scoped with the resistor bypassed. Make sure there is a cap from Vin to ground, after the resistor.
4. Your lab is haunted by ghosts, run
edit
To my eye, the datashit contains a strong hint that 2 is the case.
(If not, my bets are on 4, 1, 3 - in this order).
