Yes, I was referring to the series connection of the conducting Zener and the forward-biased BE junction.
As you increase the voltage across the series connection, the current increases quickly.
(The resistances are non-linear, but is not high for normal operating currents of the two devices.)
In some circuits (not your original one), there is substantial resistance in series with the Vcc feed to the whole circuit that limits the current.
With a simple series resistor added there, you have a shunt regulator circuit where the bulk of the current flows through the NPN transistor.
Thanks Tim, incoming noob question again-
Could you please explain a little bit more the parts you said
"(The resistances are non-linear, but is not high for normal operating currents of the two devices.)"
and
"In some circuits (not your original one), there is substantial resistance in series with the Vcc feed to the whole circuit that limits the current.
With a simple series resistor added there, you have a shunt regulator circuit where the bulk of the current flows through the NPN transistor."
By "series resistor added there" do you mean the one below the zener in my circuit. So a base resistor added should do the trick no?
Also how would I size the base resistor? The transistor is 2N3904 and the Zener is 5.1V zener diode.
Thanks again
1. The two diodes will show increasing voltage across each as the current increases: that is a non-linear resistance.
Zeners are specified for their incremental resistance at a given current level, for design purposes.
Normal diodes are governed by the Schockley diode equation, found in textbooks, for the relationship between voltage and current.
For your circuit, the problem is that if you put, say 10 V, into the circuit from a source without current limit, the current through the combination of Zener and BE junction will be huge and probably overheat the devices.
2. Sometimes, one needs a simple circuit that acts like a Zener diode with a higher current capability than the Zener itself. Your circuit will function in that way, giving a voltage across it as the sum of the Zener and BE voltages (at a relatively low current), while the equivalent Zener current is the collector current of the transistor which is much higher than the base current.
Just like with a regular Zener, you must externally limit the current, usually with a series resistor from the voltage source, or the Zener will conduct too heavily.
3. Personally, I don't like the base-resistor option, so I won't comment.
