Hi all, I'm new at forum
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
I work with Eletronics a long time ago, and I have a website about experiments (EnergyLabs Brasil
http://www.energylabs.com.br), and I am playing with samples of MAX1421 (40Msps 12BIT ADC from Maxim).
But I have a BIG problem. When I power it up after a few time, I got smoke from the ADC. But now from ADC itself, but smoke from between pins (All times that I saw, it was in the middle of a VDD and GND pin), and if I stay more time, it starts to blink like if there is burning.
First, I think of that I may shorted some pin or so, so I got a new board, new ADC from the sample package and soldered, measure ALL pins with multimeter in conduction mode to see if there was any short, after that measuring all pins to see if there was a low resistance between any pins (the datasheet says that from any input to GND the resistence is about 10k. All of it was correct. Checked with a Lens too, nothing wrong. After soldered all wires, I triple checked if there was some wiring mistake, and nothing found. So I decided to hook up on FPGA again (Xilinx Spartan 3A) and it was seens to be working (I actually dont know if it was working correct, because I didnt hook up any signal, so I was only picking up noise), but after some time, it stoped to get output and few secs later, smoke too.
Got angry with that, its free samples from Maxim but, I dont want to destroy it. But okay, got to search for problems. After that, I only hooked up the ADC to 3.3V Power Supply, and it got smoke, so I think that ADC is dead.
Asked my dad about it, see what he thinks about (he is eletronics technician too) and he said that might the wires got melt with the solder iron and nearly shorted the pins. Makes sense, so I got a new board, another ADC, soldered on the board and I make only the Power Supply connections, and this time, one wire far from the other (the max that I can do). Triple checked all things again, all correct. Got decoupling caps at the inputs as the ADC Datasheet says, and hooked up ONLY to the 3.3V Power supply. Started, and few secs later, smoke again, and light between VDD and GND Pins (random).
I really dont know what is happening, there is no short, no pins has resistance less than 10K, and the powersupply supplies 3.32V correct (also I used the same supply to a LCD Screen).
The funny thing is that, all the times I measured the current that ADC draws and all stays lower than 1mA. Only hooked at the FPGA with the clock singal (without it is the same, below 1mA) it draws near 20mA (on the datasheet this is lower than usual current, it makes sense, because I only clocking it at 16MHz not 40MHz).
I already sent a email for Maxim IC, but they didnt returned me. Someone knows what can be the problem? Here are few pics of the first board (I know, its crap, but the last one that I Didnt take pic its better, and I was carefull to not make any short or things like that):
The ADC has a PD input (Power Down, that makes the ADC got to shutdown mode). With that on 1 (shutdown state) the current is lesser than 500uA. With that in 0, the current is about 800uA to 1mA. (Of course, without the clock signal, only power supply. Also the PCB is correct, I have more 6 of them here, but only one ADC.
Thanks !
