Author Topic: Need help identifying a fan header?  (Read 1510 times)
Offline petrezaTopic starter
« on: October 12, 2015, 09:36:34 am »
Hello,
I would like change the fans of a Poweredge R810 with quieter ones. The problem is that the current fans use what appears to be a proprietary header. I want to preserve these fans so I do not want to cut and splice the headers from them to the new fans. I checked on DigiKey with no luck.
Here are some pictures:
In case the exact thing cannot be bought off the shelf, I would be happy with a header that matches the "plug" portion; I do not strictly need the flat "base" portion.
Here are the dimensions of the "plug" part:
5.8mm X 7.2mm
2.5mm - distance between the pins
10mm - the "height" of the "plug"
Thanks again for your help!
Offline amyk
Re: Need help identifying a fan header?
« Reply #1 on: October 12, 2015, 02:56:47 pm »
Is it 2.5 or 2.54mm (0.1")? Because the latter is very common.
http://www.digikey.com/product-detail/en/M20-1070200/952-2030-ND/3727994
These have the polarising key, but might not fit depending on what the key on your socket is like:
http://www.digikey.com/product-detail/en/22-55-2042/WM6442-ND/313627
http://www.digikey.com/product-detail/en/65846-014ELF/65846-014ELF-ND/4272733
Offline kolbep
    • ShoutingElectronics.com
« Reply #2 on: October 12, 2015, 03:03:41 pm »
Just use dupont jumpers (the ones with a single female socket on them)
Just plug 4 of them into the respective holes.
Put them in the socket, a dab of silicon to hold them together,
and Fanny's your Aunt
www.ShoutingElectronics.com Don't just talk about Electronics, SHOUT ABOUT IT! Electronics Blog Site and Youtube Channel
« Reply #3 on: October 17, 2015, 01:30:50 am »
Thanks for the replies!
Yes, must be the 2.54mm (.1inch) pitch. Thanks!
I have the wires and the tips and the housings and the tools on order now.
