You need the lowest dissipation factor you can find at the frequency of interest, and that's usually polypropylene. Just as a reference point, I built a small induction heater running at a similar frequency. The resonating cap was a very low loss polypropylene, yet it still got hot and I was duty cycle limited! Several caps in parallel can solve the problem.
