Hi Everyone,
So one of my current projects to to make a converter for an old BT #332 phone. I want to make it work with the newer telephone system.
There is a little room in the case for some small electronics without removing the old components. So I was thinking of small board running a ATtiny todo the detection of the pulses from the rotary encoder and convert those to DTMF. This is not a problem for me. I probably could find a DTMF generator but then I'd need to use say some 7400 series IC's to decode the rotary encoder. So I'm thinking the micro is best to keep the component count low. The part which I have limited experience with is the power supply side.. coming up with a design that will fit the requirements.
If the electronics are placed inside the the case and they get quite hot the old Bakelite case might be at risk. So I'm thinking some type of switch-mode power supply. I don't want the telephone expending too much power for no-reason since it will be idle most of the time. So when the phone rings or the handset is picked up the power is turned on. The BT spec's say the potential between the 2 telephone line terminals will not exceed 70V when off-line. The 'Call Arrival Indication' (Ringing) will be between 100V and 40V AC rms. The receiver for the handset has a switch to detect pick up.. so detecting that is not much of an issue. But still need to detect the Ringing. The BT line specs are linked to at the bottom for full details if anyone is interested.
So currently I need a way to step-down the line voltage which can vary.. to 5V DC for the micro, and detect when the phone is ringing so the micro can alert the user in some way.
I have not yet decided if I want to keep the rest of the internals. I could replace the current microphone and the speaker with newer parts (this would be preferable). The ringing bells would probably have to go.. since I have not yet worked out how I would interface this with the micro.
I have attached some images, as well as the original wiring diagram (which is printed on a label on the inside). Gone are the days manufacturers would do that!
I have purchased a new braided wire which is insulated properly and put that on you can see that in the image of the inside.
For those that are interested I have wired up a new BT phone connector to the phone and it still works! this phone is about 40 years old! They don't make them like they used to
Any help/ideas on where to go with this would be appreciated.
Thanks,
Napalm
Links:
British Telephones - BPO Telephone No. 332 and variantsBT Public Switched Telephone Network (PSTN): Technical Characteristics Of The Single Analogue Line Interface (400KB PDF)
