Hello
For a project I am working on I want to power a raspberry pi 5 with a 4-cell lipo battery, since it is going on a drone. This problem has probably been solved before, but the issue with the Rpi 5 is that it wants to "handshake" over usb c with its power supply to see if it can get 5V at up to 5A, if it cannot it will complain and limit peripheral power, regardless of what power supply you have connected to the usb C port.
My goal is to find/build a real hardware solution to this(I know you can bypass the power supply detection in software, its not ideal). I started looking at a few USB C PD controller chips, but I quickly realized that I don't exactly know what I am looking at. Most of these chips are quite complicated, and all I want is a chip that can tell the Rpi that 5V 5A is available.
What would be the best starting point? are there cheap off-the-shelf solutions already that I can't find? There are tons of little USB C PD sink modules, but not any buck converters with a source controller built in.
TLDR: I want to build a buck converter with a USB C source controller in it. I can figure out the buck converter, I just need help with the USB C part.
