Hey all, over the past few years I've been working on a design for an RGB LED driver board that can drive an array of RGB emitters. I've been asking design questions about this application for a few months now, and received some very helpful feedback. I'm several board revisions in, and I've reached the point where I think it would be helpful to open up my design to wider scrutiny to determine if the choices I have made are going to support my goals. The goals of this project were to build an LED panel that would accomplish the following:
1) Emit red, green and blue light at very specific wavelengths.
2) Cover an area of roughly 100mm x 100mm (the largest board you can make at JLCPCB without paying an extra fee, can illuminate a 120 negative).
3) Allow me to evenly mix the colors and create an even, bright field of light.
4) Control the brightness of the emitters with high precision (1024 bit PWM resolution).
5) Control the brightness of the emitters with high frequency PWM (>20khz) to avoid flicker and banding effects arising from camera shutters.
This board will be manufactured and 90% assembled by JLCPCB. After revision 3 I started getting lazy and having them solder everything SMD since it's so cheap.
The purpose of this light is pretty niche. I'm basically building a densitometry instrument for color negative film (hence the precise wavelengths of light). I basically want to use the light to sample the dye layers in the film at wavelengths defined by a standard known as status M, which was designed specifically for color negative film. The goal here is to re-create the functionality of professional film scanners with this custom light and a digital camera.
The trickiest part about this was finding an LED driving topology that could support the high PWM frequencies I wanted to achieve. After some research, I settled on an approach that TI had documented and labeled "shunt-FET LED dimming", in which the output of the LED power in a constant-current switching driver was shunted to ground through a mosfet during the PWM on period. TI helpfully provided a design for a high resolution, high PWM frequency RGBW light based on the LM3409:
https://www.ti.com/tool/TIDA-01415, which I've used as a rough basis for my own design. I've changed the form factor of the board quite a bit, swapped in an ESP32 for the C2000 Piccolo Launchpad, killed the DAC and the DMX interface and added a set of rotary encoders to control the emitter colors as well as an i2c interface to support a OLED display.
I'm using a pretty standard 4-layer stackup for the board: signal - ground - power - signal. In my last few revisions I had full ground pours on both the top and bottom signal layer, but as a result of some feedback I received here and after further investigating the TI design, I decided to kill the full ground pours (except for the ground layer of course) and just add ground pour areas where necessary. I also realized that I had ended up badly splitting up my grounds on earlier designs, and adding discrete pours let me think more carefully about where my grounds where and how to keep them unbroken. I have noted that the TI design has a split ground on the ground layer, which from what I've read is possibly not the greatest idea? I'm curious about thought on this. It seems like the LED drivers have their own ground pour. I'm wondering if they do this because the presence of the DAC on the board introduces more stringent noise requirements?
I did borrow one particular approach from the TI design that I'm not quite sure about: the gaurd traces on the PWM lines. My sense is that these mostly function to ensure that no other signal traces can get close enough to the PWM lines to couple, but that they also potentially reduce the loop area? I know that return currents are going to travel under the signal trace, though the traces in question unavoidable cross some power planes, so maybe they will help in those cases? From what I've read this strategy meets with mixed success, but I'm curious to test it out here, particularly because I was forced to change planes with these PWM lines in order to route them. Most of the other signals on the boards are slow, so I'm not that worried about them. I've definitely encountered some EMI issues with these PWM lines, and while they are only 30khz signals, the rise and fall times on the pulses are in the single ns range to allow for 10-bit PWM resolution. I'm also thinking of introducing a minimum brightness limit so that I can still have the target resolution over most of the range, but slow down the pulse rise and fall times.
In past versions, I had built an array of individua color LEDS, but this introduced really difficult color mixing problems. As a result, I inquired with a chinese company that manufactuers custom LED emitters and they were able to provide me with a decent number of custom emitters for a reasonable price. I ended up paying ~$120 for 500 emitters shipped, and the color mixing of the output light is much improved. I am still encountering an odd vignetting effect, which I think is related to the brightness of the light, so I want to test out brighter emitters in the next version. The emitters themselves are essentially three rows of 8 LED emitters in parallel. In order to address the problems of driving LEDs in parallel, I've chosen to implement this board on an aluminum substrate, which will help to spread the heat and prevent the associated over-current problems.
The design of the driver board looks a bit lopsided at this stage. The layout is constrained by the intended board size (I want the driver board to fit on top of the emitter board), and the position of the elements that need to interface with the case, like the rotary encoders and input jack. Not sure there's much I can do about that.
At this stage I am mostly focussed on controlling some issues that I believe were caused by EMI in my previous revision. Specifically, the green and blue emitters (most noticeably the green) would start to visibly flicker at intermediate PWM duty cycles (40-65%), which didn't make a lot of sense. From what I could see on my oscilloscope, I think there was some sort of noise issue on the switching node. I had some bad ground loops, particularly on the driver power inputs, so I'm hoping that by eliminating those and improving the grounding situation generally I can solve the issue.
I'm hoping for some feedback on my design, though I'm happy to answer any questions about the application, and I hope that my process can hopefully serve as a resource for anyone going down the same path. At this stage I'm specifically concerned with EMI coming from the PWM lines, the switching node of the controller and the LED power lines, so any pointers for how I can improve my approach in these areas would be super helpful. Some things I'm thinking about:
Is it OK for the emitters to share a common ground?
Should the LED drivers have a split ground from the rest of the board?
Was removing the ground pours from the signal layers a good choice?
Here's the full layout of the driver board:
Here's the layout with the signal layer highlighted:
And with the power layer highlighted:
Here's the emitter schematics:
The emitter board layout:
And an image of the partially assembled project:
I've added the full board schematic as a PDF attachment.
