Author Topic: silicon chip project  (Read 1123 times)
Offline buzzawakTopic starter
  • It's all about the data.
« on: October 05, 2019, 02:10:43 am »
July 2019 issue of Silicon chip in the Circuit Notebook section has a diagram for a 74LSxx series logic tester build around the DS89C430-MNL microprocessor.
This is my first foray into programming chips so on a steep learning curve.
The DS89C430-MNL is not a cheap chip and from my reading is pin and instruction set compatible with the older and much cheaper 80C52.
Am I demonstrating my total ignorance :-DD in thinking I can substitute the 80C52 and all will be fine?
Offline ledtester
Re: silicon chip project
« Reply #1 on: October 05, 2019, 03:03:16 am »
Do you have source code or just object code? If you have source there is a better chance you can account for any hardware differences between the two chips.
There are a lot of IC tester projects on the web, and you can make one with just an Arduino.
Both of these projects have an extensive test database:
https://www.instructables.com/id/Arduino-IC-Tester/
https://github.com/akshaybaweja/Smart-IC-Tester
For an historical perspective on IC testers, have a look at:
http://www.computernerdkev.heliohost.org/ictesters/index.htm
The following users thanked this post: noobiedoobie
« Reply #2 on: October 05, 2019, 11:13:29 am »
Hi Ledtester,
Yes, I do have the source code for it. Thanks, I will have a read of the links you kindly provided.
Offline ebclr
« Reply #3 on: October 05, 2019, 06:53:18 pm »
If you are looking for the tester, not for fun to make, it's an easier patch available
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20191005105250&origin=y&SearchText=TL866II+&switch_new_app=y
« Reply #4 on: October 06, 2019, 12:14:30 am »
Thanks, Ecdir
That's a nifty tool, the goal is fun of the build but I do like the XGecu TL866ii plus -p6
I collected a whole bunch of TTLs way back thinking they will come in handle one day.
I have decided to have a go at making an 8bit breadboard computer and what to do a tidy up on my inventory first.
