Author Topic: Anyone knows this header/connector?  (Read 7327 times)
Offline prot_brotTopic starter
  • Country: id
« on: March 20, 2015, 09:06:21 pm »
This is the header on the PCB:
...and the header's footprint:
I'm planning to make battery pack and GPIB module for my Fluke 45. Unfortunately, the main PCB has this funny looking header to connect the card via ribbon cable. I can't get any information about it.
Yes, the fastest way would be soldering wire directly to the main PCB, but I'll keep that as the last option if possible.
  • Country: id
Re: Anyone knows this header/connector?
« Reply #1 on: March 20, 2015, 09:31:54 pm »
Offline dom0
« Reply #2 on: March 20, 2015, 10:37:43 pm »
Molex PicoFlex.
The L stamped on them tells me that those are actually Lumberg Micromodul. PicoFlex might be compatible, though.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: March 20, 2015, 11:01:15 pm »
LUMBERG
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #4 on: March 20, 2015, 11:32:43 pm »
They look expensive, but also look reliable!
Don't ask a question if you aren't willing to listen to the answer.
Offline dom0
« Reply #5 on: March 21, 2015, 12:04:09 am »
Offline Psi
« Reply #6 on: March 21, 2015, 12:13:54 am »
"Would you like a $1000 tool to crimp your $0.01 crimp connector pin"
If you crimp 100,000 pin then the tool has cost you another $0.01 on top of the connector pin price.
« Last Edit: March 21, 2015, 12:15:38 am by Psi »
  • Country: id
« Reply #7 on: March 21, 2015, 05:30:28 am »
Thanks! I checked Picoflex and Lumberg Micromodul, both are very similar.
and 1255EUR for crimp tool??  :o seems like a chopstick and pliers will do the job.
Online David_AVD
« Reply #8 on: March 21, 2015, 05:36:13 am »
I had to replace a couple of those PicoFlex connectors once.  What a pain in the arse without the correct tool.  Buy a spare as you'll likely mangle the first one.
