Ah, that goes back to the days when National Semi was still around and you had mil spec devices. As National acknowledged, the chips going into the 1/2/3 ranges were all the same the only difference might have been the level of testing. Pretty sure the 150C rated devices for use would have needed the metal case, milspec which is what the 1 series was about didn't like plastic cases much in the 80's because of temp and possible outgassing at high altitudes. It was all ceramic or metal casings for semis. The 1 was for military, 2 for industrial and 3 for comercial but you probably already knew that.
