Author Topic: High ambient temperature LED  (Read 3375 times)
Offline hamdi.tnTopic starter
  • Country: tn
« on: September 07, 2015, 09:15:59 am »
Hi, been asked to design an LED board that operate in an oven with 80°C, while i found LED good enough to run in such environment and a power-supply ELG-100-C from Meanwell (can operate at 90°C) am still sceptical about a power supply that will survive long working period in that temperature, will that shorten capacitor life time in it am pretty sure they are not some cheap cap in there but what are the chances that those things will pop up too soon.
Offline coppice
Re: High ambient temperature LED
« Reply #1 on: September 07, 2015, 09:29:16 am »
I can understand why you would need to put lights in a hot place, but why would you make life hard by putting their power supply in the oven with them?
  • Country: tn
« Reply #2 on: September 07, 2015, 09:41:15 am »
don't get it either ... i asked to same question, they asking for it to be like that , those light are replacement for some old light so AC cable are in there already. Am not sure if they can make any hack inside the thing or how easy to access those wires. but even if they can am still interested to know what are the risks.
Edit : it's a huge oven, a room size oven.
« Last Edit: September 07, 2015, 09:43:01 am by hamdi.tn »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #3 on: September 07, 2015, 11:01:27 am »
Tell them the prices of psu inside and psu outside. They'll turn.
Offline MikeW
  • Self confessed noob
« Reply #4 on: September 07, 2015, 11:31:48 am »
Beware that 90°C is the Tcase max temperature, not the maximum rated ambient temperature.
I would be surprised if you could sit that in an 80°C oven, switch it on and not exceed the Tc.
  • Country: tn
« Reply #5 on: September 07, 2015, 12:04:34 pm »
can't agree more.
however this psu will be attached to a metallic structure 1.5m / 0.15m / 0.3m so i was thinking how safe will it be to consider that this will be enough to maintain case temperature between that range of  80° to 90°C
Offline MikeW
« Reply #6 on: September 07, 2015, 12:17:13 pm »
I would have thought that if it's an oven then there would be insulation outside the metallic structure though?
  • Country: tn
« Reply #7 on: September 07, 2015, 01:17:15 pm »
The metallic structure am talking about is the led fixture itself not the oven so no insulation outside of it.
Offline ruffy91
« Reply #8 on: September 07, 2015, 01:30:56 pm »
Why even bother about LEDs? The power they save will be used by the oven because the heating power from the bulbs is missing :-). And at 80 degrees celsius or even higher the efficiency from LEDs will be very low.
  • Country: tn
« Reply #9 on: September 07, 2015, 01:43:12 pm »
there is a saying in my country  " they sell the monkey and they laugh at the own who buy it " that's what marketing ppl do  :P
you asking the wrong man why they need LED  :P i mean if everytime someone came to an EE and say ... hey i need that thing that do stupid stuff can't you do it for us , and we say why bother we will be out of business you know  :-DD
