Author Topic: own build 3D printer  (Read 2301 times)
Offline akisTopic starter
« on: May 09, 2017, 07:21:36 pm »
I vaguely remember there was some open source (?) project to design/create/build your own 3D printer. Could someone please suggest the project?
Re: own build 3D printer
« Reply #1 on: May 09, 2017, 07:25:25 pm »
ahh, it's reprap I think!
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: May 09, 2017, 08:09:05 pm »
joint the club http://forums.reprap.org/ and you'll have lesser and lesser time than you can imagine...
« Reply #3 on: May 10, 2017, 08:08:43 am »
Sounds like a lot of work though? As a parallel imagine if your Laser Scanner/Copier/Printer from Amazon arrived in bits and you'd have to put it all together including controllers for the lasers, the mirrors, the sheet feeders, then write the software for those MCUs etc
  • Country: my
« Reply #4 on: May 10, 2017, 12:38:14 pm »
Offline Zinger
« Reply #5 on: May 10, 2017, 01:04:53 pm »
My local MakerSpace has several slightly modified Prusa I3 printers.  Nice machines, solid and good print quality.
http://shop.prusa3d.com/en/3d-printers/59-original-prusa-i3-mk2-kit.html
"It's better to ask a stupid question than to make an expensive mistake."
