What's your intended voltage and current, and do you need to switch fast?
I'm looking for general purpose ORing controllers for 3 to 10V, 2A max, and ~1us switching.
The two use cases are:
(1) Simple solar battery charging for small devices, I need to prevent backflow from battery to charging buck converter and quiescent current on the battery side (output side) must be low (~10uA).
(2) Automatic power source switching for USB devices with builtin battery, where attaching USB power should switch power source from battery to USB with no interruptions.
The controller should be around $0.5 or less.
